" The Cloud"
wrecker
wrecker
Posts: 21, Visits: 201
This is really a question to Tim.
I was trying to save a waypoint file to "the Cloud" and found the file was too large.
Please could you advise what the maximum file size is, and then I will reduce mine to that.
Tags
We've recently changed the cloud limitations and you should find it saves fine now.
wrecker
wrecker
Tim
Many thanks I have just tried it out and all OK
hvdberss
hvdberss
Too Much Forum (113 reputation)Too Much Forum (113 reputation)Too Much Forum (113 reputation)Too Much Forum (113 reputation)Too Much Forum (113 reputation)Too Much Forum (113 reputation)Too Much Forum (113 reputation)Too Much Forum (113 reputation)Too Much Forum (113 reputation)
Posts: 1, Visits: 5
I am a new user. I worked in Skydemon on Windows8 PC and want to pick up aircraftdata (which are saved in the cloud from PC) from my Ipad.
But I cannot find stored plans and aircraftdata. What can be wrong ?
Where are you looking? Open from Cloud is available on the Route menu and in the Aircraft screen on SkyDemon for PC.
Paranut
Paranut
Too Much Forum (339 reputation)Too Much Forum (339 reputation)Too Much Forum (339 reputation)Too Much Forum (339 reputation)Too Much Forum (339 reputation)Too Much Forum (339 reputation)Too Much Forum (339 reputation)Too Much Forum (339 reputation)Too Much Forum (339 reputation)
Posts: 3, Visits: 17
I'm running Windows 8 64 bit and version 2.6.3.0 of SkyDemon. I cannot access the cloud, even with my firewall turned off. Is there a known problem with this setup or am I missing something? I can access the cloud no problem on my Android but unless I can do so for the PC too, it makes my flight planning etc a little more awkward than I hoped.
Brett
There is no known problem. If we are to help you, you'll need to share details of the error message(s) you are seeing.
Paranut
Paranut
When I click on OpenFileFromCloud on the PC, it just shows nothing there, even though I can see it from a Win7 PC and on my android device. Similarly for Waypoints. In short, the cloud is not visible to the Win8 PC. I can access charts and things though no problem. It is just cloud stuff that is not visible. It is not in offline mode.
Paranut
Paranut
Ah ha. I cracked it. I had to Logout from the setup menu, then log in again and it all started working. Great. Now I can get on and finish planning the RoundBriatainRally flight!
