Skydemon on Linux
gfry
gfry
Too Much Forum (584 reputation)Too Much Forum (584 reputation)Too Much Forum (584 reputation)Too Much Forum (584 reputation)Too Much Forum (584 reputation)Too Much Forum (584 reputation)Too Much Forum (584 reputation)Too Much Forum (584 reputation)Too Much Forum (584 reputation)
Group: Awaiting Activation
Posts: 3, Visits: 102
So far working on:
Ubuntu 12.04 LTS 32bit Desktop
Linux Mint 12 32 bit.
Linux Mint 12 64 bit.
1) Install winetricks
2) Run the following command from a terminalsession
Winecfg
When Wine Configuration pops up, click OK
3) Run the following command from a terminalsession
wget http://winetricks.googlecode.com/svn/trunk/src/winetricks
4) Run the following command from a terminalsession
bash winetricks dotnet30sp1
This will popup a Mozilla session and ask youto download dontnet 2.0
5) After downloading dotnet 2.0, run the followingcommands from a terminal session
Cd Downloads
Cp dotnetfx.exe /home/xxxx/.cache/winetricks/dotnet20
6) Run the following command from a terminalsession
This will start the dotnet2.0 installtion. Follow the installation prompts. Once the dotnet2.0 installation completesclick Finish
7) Run the following command from a terminalsession
wgethttp://winetricks.googlecode.com/svn/trunk/src/winetricks
8) Run the following command from a terminalsession
This will popup a Mozilla sessions and ask youto download dontnet 3.0
After downloading dotnet 3.0, run the following commands from aterminal session
Cd Downloads
Cp netframework3.exe/home/xxxx/.cache/winetricks/dotnet30
9) Run the following command from a terminalsession
This will start the dotnet3.0 installation. Follow the installation prompts. Once the dotnet3.0 installation completesclick Finish
Note: Dotnet3.0installer disappears on to the toolbar at the top. Simply right click on the installer icon onthe tool bar and select View Progress details
10) When Dotnet3.0 installer completes it willautomatically start XPS Esstentials Pack setup wizard, follow throughinstallation wizard. Ensure you selectregister for the the XPS document viewer.
11) When XPS Esstentials Pack setup wizardcompletes it will automatically start dotnet3.0Sp1 installer, follow throughinstallation wizard. Ensure you selectregister for the the XPS document viewer.
12) When dotnet3.0Sp1 installer finishes, Run thefollowing command from a terminal session
bash winetricks gdiplus
This will popup a Mozilla sessions and ask youto download .Net Framework 1.0 GDIPLUS.DLL Security Update
After downloading .Net Framework 1.0 GDIPLUS.DLL SecurityUpdate, run the following commands from a terminal session
Cd Downloads
Cp netframework3.exe /home/xxxx/.cache/winetricks/gdiplus
13) Run the following command from a terminalsession
This will start the gdiplus installation.
14) Download Skydemon from www.skydemon.aero
15) Install Skydemon via winetricks
Hey Presto you now have skydemon running onUbuntu.
Now to get wine/SD to read and write from your SD card/Card reader
1) Run the following command from a terminal sessiom
winecfg
2) when Wine Config opens select the Drives tab and click Add, then select a drive letter that you want to add.
3) once the dive shows in the drive mapping window, highlight it. Then select browse, and browse to media and then the ID of the SD card, then click OK
4) Highlight the drive you created again in drive mapping and select Show Advanced, in the Type drop down select Floppy Disk. Click OK.
5) In Skydemon go to Setup then device connectivity options. Click on Install SkyDemon on a new Windows CE device. Then select the new drive that you created. Click Next, select the mspd you want to sync, then click OK.
Once step 5 has been completed you can just use the sync button in the future.
blah blah blah
Runways
Runways
Posts: 309, Visits: 1.6K
flycycledave: Thank you very much for keeping this thread alive. I am still having problems installing SD on the 64 bit machine. The 32 bit was no problem. I would not dare update the 32 bit though to the latest SD in case it stopped working altogether. I hope gfry and others interested Linux installation would one day come up with something that is much easier to use, akin to a ppa to make everyone's life much easier.
Quite honestly, I have not used windows for years, and Apple issues of SD have their limitations. Also Apple is now at loggerheads with Samsung in various countries in court cases worth Billion. Who knows what will happen next. Fortunately I have been using Linus's Linux for the past 5 years. I do not see myself giving it up any time soon for the others.
Very Newbytheway
DurhamTeaseAirport
flycycledave
flycycledave
Too Much Forum (278 reputation)Too Much Forum (278 reputation)Too Much Forum (278 reputation)Too Much Forum (278 reputation)Too Much Forum (278 reputation)Too Much Forum (278 reputation)Too Much Forum (278 reputation)Too Much Forum (278 reputation)Too Much Forum (278 reputation)
Posts: 2, Visits: 13
Runways. I am using the android version of SD on a galaxy tablet - works well. Until I can get the full version installed on my Linux machine, I've gone back to an old laptop with Windows Vista on it, so I can work on the laptop, save stuff to the cloud and then download it onto the tablet, which I take flying. I've only been trying SD for a couple of weeks, but I'm very impressed.
cheers
Runways
Runways
Thanks flycycledave.
I actually used SD on an Android tablet and mobile phone. It is good. Having said that I do not seem to be able to do all my work within Android platform only. Also Linux being so robust, stable, and created and maintained by dedicated people who do not seem to have obvious commercial affiliation means something.
Of course the lack of tablets fully compatible with Linux is another factor, although they are in the works.
Very Newbytheway
DurhamTeaseAirport
Vic
Vic
Too Much Forum (379 reputation)Too Much Forum (379 reputation)Too Much Forum (379 reputation)Too Much Forum (379 reputation)Too Much Forum (379 reputation)Too Much Forum (379 reputation)Too Much Forum (379 reputation)Too Much Forum (379 reputation)Too Much Forum (379 reputation)
Posts: 4, Visits: 29
I am having exactly the same problem as flycycledave, however I am only using the 32 bit version of Ubuntu 13.04
Seems like its an issue with the latest Ubuntu?
Vic
gfry - 10/11/2012 1:14:22 PM
C82R - 10/30/2012 8:59:53 PM
stevelup - 10/31/2012 8:10:38 AM
             Many Thanks I'll try that
C82R - 10/31/2012 7:06:53 PM
Runways - 11/1/2012 3:00:06 PM
gfry - 11/1/2012 4:03:11 PM
Runways - 11/4/2012 10:07:33 PM
Runways - 11/8/2012 10:52:34 PM
stevelup - 11/9/2012 8:06:10 AM
Runways - 11/9/2012 11:56:55 AM
Runways - 11/11/2012 7:54:55 PM
gfry - 11/12/2012 5:50:51 PM
                         Many thanks Gfry. I'll try that.
Runways - 11/13/2012 4:58:06 AM
                             Do you know Gfry , while the 32bit Linux installation went like a...
Runways - 11/16/2012 12:10:25 PM
flycycledave - 6/5/2013 7:31:52 PM
Runways - 6/6/2013 12:40:13 PM
flycycledave - 6/6/2013 7:56:48 PM
Runways - 6/6/2013 11:02:36 PM
                         I am having exactly the same problem as flycycledave , however I am...
Vic - 6/28/2013 12:10:34 PM
