So far working on:
Ubuntu 12.04 LTS 32bit Desktop
Linux Mint 12 32 bit.
Linux Mint 12 64 bit.
1) Install winetricks
2) Run the following command from a terminalsession
Winecfg
When Wine Configuration pops up, click OK
3) Run the following command from a terminalsession
wget http://winetricks.googlecode.com/svn/trunk/src/winetricks
4) Run the following command from a terminalsession
bash winetricks dotnet30sp1
This will popup a Mozilla session and ask youto download dontnet 2.0
5) After downloading dotnet 2.0, run the followingcommands from a terminal session
Cd Downloads
Cp dotnetfx.exe /home/xxxx/.cache/winetricks/dotnet20
6) Run the following command from a terminalsession
This will start the dotnet2.0 installtion. Follow the installation prompts. Once the dotnet2.0 installation completesclick Finish
7) Run the following command from a terminalsession
wgethttp://winetricks.googlecode.com/svn/trunk/src/winetricks
8) Run the following command from a terminalsession
This will popup a Mozilla sessions and ask youto download dontnet 3.0
After downloading dotnet 3.0, run the following commands from aterminal session
Cd Downloads
Cp netframework3.exe/home/xxxx/.cache/winetricks/dotnet30
9) Run the following command from a terminalsession
This will start the dotnet3.0 installation. Follow the installation prompts. Once the dotnet3.0 installation completesclick Finish
Note: Dotnet3.0installer disappears on to the toolbar at the top. Simply right click on the installer icon onthe tool bar and select View Progress details
10) When Dotnet3.0 installer completes it willautomatically start XPS Esstentials Pack setup wizard, follow throughinstallation wizard. Ensure you selectregister for the the XPS document viewer.
11) When XPS Esstentials Pack setup wizardcompletes it will automatically start dotnet3.0Sp1 installer, follow throughinstallation wizard. Ensure you selectregister for the the XPS document viewer.
12) When dotnet3.0Sp1 installer finishes, Run thefollowing command from a terminal session
bash winetricks gdiplus
This will popup a Mozilla sessions and ask youto download .Net Framework 1.0 GDIPLUS.DLL Security Update
After downloading .Net Framework 1.0 GDIPLUS.DLL SecurityUpdate, run the following commands from a terminal session
Cd Downloads
Cp netframework3.exe /home/xxxx/.cache/winetricks/gdiplus
13) Run the following command from a terminalsession
This will start the gdiplus installation.
14) Download Skydemon from www.skydemon.aero
15) Install Skydemon via winetricks
Hey Presto you now have skydemon running onUbuntu.
Now to get wine/SD to read and write from your SD card/Card reader
1) Run the following command from a terminal sessiom
winecfg
2) when Wine Config opens select the Drives tab and click Add, then select a drive letter that you want to add.
3) once the dive shows in the drive mapping window, highlight it. Then select browse, and browse to media and then the ID of the SD card, then click OK
4) Highlight the drive you created again in drive mapping and select Show Advanced, in the Type drop down select Floppy Disk. Click OK.
5) In Skydemon go to Setup then device connectivity options. Click on Install SkyDemon on a new Windows CE device. Then select the new drive that you created. Click Next, select the mspd you want to sync, then click OK.
Once step 5 has been completed you can just use the sync button in the future.
