Visits: 12
I had the same problem yesterday evening exactly as described. I use a Dual Electronics XGPS150 so was not expecting this problem. After I got home I tried tried again. Skydemon found me, showed a yelow aircraft which then turned red and only went back to yellow if I "stopped navigating" and then went flying. it repeated this every time. The Dual GPS app showed satellites and a position. I will go home this evening and reboot the ipad to see if that is the cause and will post if the problem is solved. Needless to say I am concerned since I was relying on the ipad as the primary Nav tool, Fortunately I was local and could go back to the chart and find my way home but when you are solo that is the last thing you need.
Will post if the reboot sorts out the problem. Hope the guys at Sky Demon read these posts as certainty on the ipad is key to the product.
Neils
