Visits: 12
Is there a way to set a custom cruising level when filing a flightplan on the iPad? The field isn't editable from the default VFR setting. Where I live ATC normally gives us a clearance for filed altitude/level right away without further requests but this doesn't work when I cannot alter the cruising level from VFR. Otherwise, everything works just perfectly.
