Filing flightplans with cruising level on the ipad
http://forums.skydemon.aero/Topic9252.aspx
By skarppi - 5/14/2013 4:32:41 PM
Is there a way to set a custom cruising level when filing a flightplan on the iPad? The field isn't editable from the default VFR setting. Where I live ATC normally gives us a clearance for filed altitude/level right away without further requests but this doesn't work when I cannot alter the cruising level from VFR. Otherwise, everything works just perfectly.
By Tim Dawson - 5/15/2013 1:05:20 PM
Sorry, that feature isn't currently available for iPad. We will consider adding it for a future release, though it's too late to be included in the forthcoming 2.6.3 release.
