What I would like is...a better way of handling alternative routes
Ramscroft
Ramscroft
Posts: 13, Visits: 104
I often plan a long route outside controlled airspace but have in mind short cuts through controlled airspace if granted. An example would be Southend to Nuthamptead. The long route is DCT LAM DCT BPK DCT. The short route goes direct via the Stansted overhead, if Essex radar let me.
What I would like to be able to do is to put both routes in my plan (and on my plog), so that I'm prepared for either. This is similar to the way alternate destinations are handled, a leg in the route that you might or might not fly, but obviously in the middle of a route instead of just at the end.
I would also prefer to have the ability to plan the route to the alternate. As it is now, it is just a straight line to the alternate but that may cross controlled airspace. It would be better if it were possible to put additional weigh points in the route to the alternate.
Ray
It would actually be useful to be able to do a "long tap" on a waypoint and choose "direct to" from the context menu. That should be easy enough and would be quite useful.
What a brilliant idea! It gets my vote.
6332, SD 4.1.2
