Mobile SD and Version 2.6.0
hughmurray
hughmurray
Too Much Forum (609 reputation)Too Much Forum (609 reputation)Too Much Forum (609 reputation)Too Much Forum (609 reputation)Too Much Forum (609 reputation)Too Much Forum (609 reputation)Too Much Forum (609 reputation)Too Much Forum (609 reputation)Too Much Forum (609 reputation)
Posts: 5, Visits: 12
I have been using my mobile SD with Windows 8 quite happily until yesterday evening. I successfully upgraded my Sky Demon Plan to 2.6.0 but when I attempted a sync, the sync failed with the message "GUID should contain 32 digits with 4 dashes". I used my computer to open a file called debug.txt and the relevant part is reproduced below. The problem is that my Mobile SD is now completely dead. It boots as far as the terms and conditions screen and then falls back to the GPS/Media/Bluetooth etc. screen. I have used the contact form to ask SkyDemon for their opinion and they have not had time to reply as yet, so if Sky Demon is reading this, be aware that this is a duplicate request for help. These things always happen at weekends!
Debug text:
Begin Exception FormatException at 2013/04/12 18:12:03
Product: SkyDemon Mobile
Version: 2.6.0.32572
System.FormatException: FormatException
at System.Guid..ctor(String g)
at Divelements.Aviation.Loaders.SkyDataManager.ReadHeadersOrNullFromStream(String filename, Stream stream)
at Divelements.Aviation.Loaders.SkyDataManager.GetLatestCharts(IEnumerable`1 chartFiles)
at Divelements.SkyDemon.x139db2a0702039b7.x5c0d7a712ade515a()
at Divelements.SkyDemon.x139db2a0702039b7..ctor(x173d7d688a9ab88a environment, EarthPosition lastKnownPosition)
at Divelements.SkyDemon.x173d7d688a9ab88a..ctor()
at Divelements.SkyDemon.x867eb3246b182488.x9d21ea182cd19cfd(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at Divelements.SkyDemon.x210ff09a2516b1a7.xafa104132a6a42b3(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.Windows.Forms.Timer._WnProc(WM wm, Int32 wParam, Int32 lParam)
at System.Windows.Forms.ApplicationThreadContext._InternalContextMessages(WM wm, Int32 wParam, Int32 lParam)
at Microsoft.AGL.Forms.EVL.EnterMainLoop(IntPtr hwnMain)
at System.Windows.Forms.Application.Run(Form fm)
at Divelements.SkyDemon.x867eb3246b182488.x160a0bf4de8f6bd0(x210ff09a2516b1a7 xafda855cbcd154fd)
at Divelements.SkyDemon.x867eb3246b182488.xc447809891322395(String[] xce8d8c7e3c2c2426)
End Exception
Hugh Murray
PPL and member of Arrow Syndicate G-AYAC
hughmurray
hughmurray
Hannah at SkyDemon has sorted this out for me. The procedure was to delete the charts from the SD device, do the same for the PC and then download a new chart to the PC and sync.
Appropriate part of her message follows:
To delete charts from your Mobile SD you'll need toconnect the device to your PC, then click Computer and select your SkyDemondevice and open the Resident Flash drive. You will then need to open the SkyDemon folder and inside this the Datafolder. In SkyDemon Data you will see anumber of .skydata files, each corresponding to a loaded chart. You will need to delete each of these skydatafiles.
Next you should delete all of the .skydata filesin your SkyDemon folder in Documents on your PC. This means that the next time you launch theSkyDemon software on your PC you'll be prompted to install new charts, and Iwould suggest installing only the ones you need.
Hugh Murray
