To delete charts from your Mobile SD you'll need toconnect the device to your PC, then click Computer and select your SkyDemondevice and open the Resident Flash drive. You will then need to open the SkyDemon folder and inside this the Datafolder. In SkyDemon Data you will see anumber of .skydata files, each corresponding to a loaded chart. You will need to delete each of these skydatafiles.
