Installation of 0.9.8
Highflyer1000
Highflyer1000
Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)
Posts: 1, Visits: 1
Application installed ok. All previous versions worked. I get the following errors: -
System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
   at Divelements.Mapping.ComplexGeometry.xed3e11f57244d7cb()
   at Divelements.Mapping.TwoDimensionalGeometry.GetPoints()
   at Divelements.Aviation.FlightPlanner.Rendering.x2c1c98f7e7ef4c48.x1a89deb7cc499658(GeometryEntity x4181df4cd38a69a0)
   at Divelements.Aviation.FlightPlanner.Rendering.x2c1c98f7e7ef4c48.x309a321eaca6b213(GeometryEntity x4181df4cd38a69a0)
   at Divelements.Aviation.FlightPlanner.Rendering.x2c1c98f7e7ef4c48.xdde427ad235f604b(Graphics x41347a961b838962, GeometryEntity xa9a706768ab5b5b1, Pen x90279591611601bc)
   at Divelements.Aviation.FlightPlanner.Rendering.xc33d26eab04d7957.x32e22c96910a9b10(x2c1c98f7e7ef4c48 xd0bb5d9c9ba91857, xd7cb7ac31049ffae x0f7b23d1c393aed9, AirspaceEntity xa9a706768ab5b5b1)
   at Divelements.Aviation.FlightPlanner.Rendering.x867d3d2864d7f7d1.DrawGeometryEntity(xd7cb7ac31049ffae context, GeometryEntity entity)
   at Divelements.Aviation.FlightPlanner.Rendering.x2c1c98f7e7ef4c48.xe406325e56f74b46(Graphics x41347a961b838962, Rectangle xe831729bf4ec9571)
   at Divelements.Aviation.FlightPlanner.Rendering.x970ba8497cedc724.OnPaint(PaintEventArgs e)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativewindow.WndProc(Message& m)
   at System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4200 (NetFxQFE.050727-4200)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
SkyAngel
    Assembly Version: 0.9.8.16605
    Win32 Version: 0.9.8.16605
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyAngel%20Plan/SkyAngel.exe
    Win32 Version: 2.0.50727.4016 (NetFxQFE.050727-4000)
System
System.Drawing
Divelements.SandGrid
    Assembly Version: 2.2.1.1
    Win32 Version: 2.2.1.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyAngel%20Plan/Divelements.SandGrid.DLL
SandDock
    Assembly Version: 3.0.5.1
    Win32 Version: 3.0.5.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyAngel%20Plan/SandDock.DLL
SandBar
    Assembly Version: 1.4.2.1
    Win32 Version: 1.4.2.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyAngel%20Plan/SandBar.DLL
System.Web.Services
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
System.Xml
enabled.
For example:
<configuration>
</configuration>
Any ideas?
Thanks for that. I think our obfuscation software has caused this in the latest release. Can you confirm if you're running 64bit Windows? Also, could you contact me through the SkyAngel site so that I can email you a test build and you could verify whether it fixes your issue?
