Installation of 0.9.8
http://forums.skydemon.aero/Topic72.aspx
By Highflyer1000 - 10/25/2009 7:00:12 PM
Application installed ok. All previous versions worked. I get the following errors: -
System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
   at Divelements.Mapping.ComplexGeometry.xed3e11f57244d7cb()
   at Divelements.Mapping.TwoDimensionalGeometry.GetPoints()
   at Divelements.Aviation.FlightPlanner.Rendering.x2c1c98f7e7ef4c48.x1a89deb7cc499658(GeometryEntity x4181df4cd38a69a0)
   at Divelements.Aviation.FlightPlanner.Rendering.x2c1c98f7e7ef4c48.x309a321eaca6b213(GeometryEntity x4181df4cd38a69a0)
   at Divelements.Aviation.FlightPlanner.Rendering.x2c1c98f7e7ef4c48.xdde427ad235f604b(Graphics x41347a961b838962, GeometryEntity xa9a706768ab5b5b1, Pen x90279591611601bc)
   at Divelements.Aviation.FlightPlanner.Rendering.xc33d26eab04d7957.x32e22c96910a9b10(x2c1c98f7e7ef4c48 xd0bb5d9c9ba91857, xd7cb7ac31049ffae x0f7b23d1c393aed9, AirspaceEntity xa9a706768ab5b5b1)
   at Divelements.Aviation.FlightPlanner.Rendering.x867d3d2864d7f7d1.DrawGeometryEntity(xd7cb7ac31049ffae context, GeometryEntity entity)
   at Divelements.Aviation.FlightPlanner.Rendering.x2c1c98f7e7ef4c48.xe406325e56f74b46(Graphics x41347a961b838962, Rectangle xe831729bf4ec9571)
   at Divelements.Aviation.FlightPlanner.Rendering.x970ba8497cedc724.OnPaint(PaintEventArgs e)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   at System.Windows.Forms.Control.WmPaint(Message& m)
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4200 (NetFxQFE.050727-4200)
SkyAngel
    Assembly Version: 0.9.8.16605
    Win32 Version: 0.9.8.16605
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyAngel%20Plan/SkyAngel.exe
    Win32 Version: 2.0.50727.4016 (NetFxQFE.050727-4000)
System
System.Drawing
Divelements.SandGrid
    Assembly Version: 2.2.1.1
    Win32 Version: 2.2.1.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyAngel%20Plan/Divelements.SandGrid.DLL
SandDock
    Assembly Version: 3.0.5.1
    Win32 Version: 3.0.5.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyAngel%20Plan/SandDock.DLL
SandBar
    Assembly Version: 1.4.2.1
    Win32 Version: 1.4.2.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyAngel%20Plan/SandBar.DLL
System.Web.Services
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
System.Xml
enabled.
For example:
<configuration>
</configuration>
Any ideas?
By JohanSvanberg - 10/31/2009 1:29:57 PM
Hi!
I have the same error on my Windows 7 64-bit computer.
/Johan
