Charts and Aeronautical Data
Finland
Finland
Finland
Kmanfi
Kmanfi
posted 8/16/2012 7:18:47 PM
HOT
Visits: 32
Hello, I found some issues. But hey, only these!
I verified all airfields in Finland and read finnish AIP to found these.
THE LEVEL OF VFR FLIGHTS
4.5 VFR is fixed in FPL.
https://ais.fi/ais/vfr/gen_en/flight_plans.html#1003270
12.6 missing airfields, eg. EFMN, EFLL, EFLN, EFPA, EFVL, EFVP, EFVI
https://ais.fi/ais/vfr/aerodromes/aerodrome_toc.html
1.3 Missing FIR sectors, 1-7 FIR sectors
https://ais.fi/ais/vfr/gen_en/airspace_classification.html#1010287
and sector frequencies. See "TAMPERE RADAR" in
https://ais.fi/ais/vfr/gen_en/air_traffic_services.html#1003963
1.2.1 Missing Protection zones eg. around EFFO
https://ais.fi/ais/vfr/gen_en/airspace_classification.html#1003418
Closed RWs are missing like EFHJ, EFHI, EFJP, EFMP, EFVU
See link.
http://www.lentopaikat.net/english.shtml
Missing noise abatement area around Helsinki downtown. See VAC.
https://ais.fi/ais/eaip/aipcharts/efhf/EF_AD_2_EFHF_VAC.pdf
There are several abatement areas in Finland. Above is one example.
Missing two protection zones for industrial plants.
https://ais.fi/ais/eaip/pdf/enr/EF_ENR_5_3_EN.pdf
Nice to have feature
-Visualize upper air sounding balloons mentioned in the previous link. Would be nice if wind direction is used to shade probability of area where it might be.
- route warnings about bird migration. See.
https://ais.fi/ais/eaip/pdf/enr/EF_ENR_5_6_EN.pdf
Br.
Kmanfi
Tags
Finland
suomi
Kmanfi
Kmanfi
posted 3/8/2013 8:45:27 AM
Visits: 32
The ACC area coordinates, frequencies and call signas are published in AIP.
Here is a link to the
AIP
Tags
Finland
Finland
Kmanfi
Thanks for your feedback. I'll respond to your points individually. I...
8/20/2012 3:54:11 PM
Hello, see comments below. I do not understand how the link...
Kmanfi
2/11/2013 1:48:08 PM
[quote] I do not understand how the link to the level of VFR flights...
E-gun
2/26/2013 2:36:54 PM
[quote]In a VFR FP - and that is what SD is about - you can not...
2/27/2013 10:26:34 AM
In Denmark a VFR flightplan will be rejected if the level is other...
E-gun
2/27/2013 1:13:49 PM
FYI SkyDemon Team. Finnish Aviation author released today brand new...
Kmanfi
3/7/2013 12:43:09 PM
The default option in SkyDemon is to generate VFR as opposed to a...
3/7/2013 5:36:50 PM
The ACC area coordinates, frequencies and call signas are published in...
Kmanfi
3/8/2013 8:45:27 AM
Aha, are you referring to the 7 sectors mentioned next to the FIR...
3/11/2013 5:34:30 PM
Yes.
Kmanfi
3/22/2013 9:18:10 AM
Thank you. We will do this work today, and the FIS will be in the next...
3/22/2013 11:23:22 AM
