Visits: 26
All, I have done quite a lot of work looking at transferring between Skydemon and G1000.
In summary the feature doesn't work at the moment. I have identified the following issues with the SD export file
1) The filename must be .fpl (lowercase) The G1000 does not recognise .FPL (uppercase)
2) The <comment /> lines need to be edited to <comment></comment>
3) The <country-code /> needs to have a value e.g. <country-code >EG</country-code>
4) The <waypoint-country-code /> needs to have a value e.g. <waypoint-country-code >EG</waypoint-country-code>
I have manually edited a couple of files and they seem to work fine.
More than happy to send SD example files etc. Just drop me a line
Phil
