1.4 beta
screetch82
screetch82
Posts: 123, Visits: 176
hi
i just uploaded the new 1.4 beta (which is still called 1.3.3. strangly) and i like it
The Mag track is now showing and if you dont use the direction instrument you get a bearing to your track.
I noticed that when simulating a flight  I pointed the aircraft directly towards the next waypoint and i was maybe 1 mile off track.
The indicator however still showed me to turn a further 10 degrees. Does this mean now it advises you of a bearing back to your track instead of the bearing from your current position towards the next waypoint? (You explained to me before the later was the case - this now seems to have changed?)
i will hopefully go flying later this afternoon so i can also test it in the air.
It always shows the bearing or correction needed to take you to the next waypoint.
If you believe something to be in error please post a screenshot and we'll take a look.
screetch82
screetch82
no error, it worked absolutely brilliant yesterday.
one thing I noticed: the airspace warning constantly stayed on until I acknowledged them - can this be right?
Yes, this is the way it has always worked. The alternative would be for them to disappear after a period of time, during which you might not have seen them. They therefore appear as long as they remain applicable.
