1.4 beta
http://forums.skydemon.aero/Topic834.aspx
By screetch82 - 7/31/2010 10:22:42 AM
hi
i just uploaded the new 1.4 beta (which is still called 1.3.3. strangly) and i like it
The Mag track is now showing and if you dont use the direction instrument you get a bearing to your track.
I noticed that when simulating a flight  I pointed the aircraft directly towards the next waypoint and i was maybe 1 mile off track.
The indicator however still showed me to turn a further 10 degrees. Does this mean now it advises you of a bearing back to your track instead of the bearing from your current position towards the next waypoint? (You explained to me before the later was the case - this now seems to have changed?)
i will hopefully go flying later this afternoon so i can also test it in the air.
By Tim Dawson - 8/2/2010 11:13:06 AM
Yes, this is the way it has always worked. The alternative would be for them to disappear after a period of time, during which you might not have seen them. They therefore appear as long as they remain applicable.
