Visits: 50
Hello, Will the flight plan generator be updated with the new flight plan symantic, active as of November 15th? Note that copying FP data generated by Skydemon 2.4.3 into the test application found at EuroControl still gives errors.
Visits: 50
More over, according the latest circulars (related to the global flight plan changes) the NAV/COM types mentioned below can be selected under item 10 of the ICAO flight plan. Lots of them are not available in Skydemon. PS: besides specific NAV-COM equipment like VFR radio, I notice most VFR pilots simply enter S for ´Standard´ which is also not available in Skydemon.
Will this be corrected?
Item 10: equipment and capabilities Numerous changes have been made to this provision. It is important to note that item 10 now also indicates capabilities, which consists of three elements: presence of relevant serviceable equipment on board the aircraft; equipment and capabilities commensurate with flight crew qualifications; and, where applicable, authorisation from the appropriate authority. The following provisions are applicable to item 10a (radio communication, navigation and approach aid equipment and capabilities). Insert one letter as follows: N if no COM/NAV/approach aid equipment for the route to be flown is carried, or the equipment is unserviceable, or S if standard COM/NAV/approach aid equipment for the route to be flown is carried and serviceable (see Note 1), and/or insert one or more of the following letters to indicate the serviceable COM/NAV/approach aid equipment and capabilities available: A GBAS landing system J7 CPDLC FANS 1/A SATCOM (Iridium) B LPV (APV with SBAS) K MLS C LORAN C L ILS D DME M1 ATC RTF SATCOM (INMARSAT) E1 FMC WPR ACARS M2 ATC RTF (MTSAT) E2 D-FIS ACARS M3 ATC RTF (Iridium) E3 PDC ACARS O VOR F ADF P1-P9 Reserved for RCP G GNSS (see Note 2) R PBN approved (see Note 4) H HF RTF T TACAN I Inertial navigation U UHF RTF J1 CPDLC ATN VDL Mode 2 (see Note 3) V VHF RTF J2 CPDLC FANS 1/A HFDL W RVSM approved J3 CPDLC FANS 1/A VDL Mode 4 X MNPS approved J4 CPDLC FANS 1/A VDL Mode 2 Y VHF with 8.33 kHz channel spacing capability 1) If the letter S is used, standard equipment is considered to be VHF RTF, VOR and ILS, unless another combination is prescribed by the appropriate ATS authority. 2) If the letter G is used, the types of external GNSS augmentation, if any, are specified in item 18 following the indicator NAV/ and separated by a space. 3) See RTCA/EUROCAE interoperability requirements standard for ATN Baseline 1 (ATN B1 INTEROP Standard DO- 280B/ED-110B) for data link services air traffic control clearance and information/air traffic control communications management/ air traffic control microphone check. 4) If the letter R is used, the performance based navigation levels that can be met shall be specified in item 18 following the indicator PBN/. Guidance material on the application of performance based navigation to a specific route segment, route or area is contained in the Performance Based Navigation Manual (Doc 9613). 5) If the letter Z is used, specify in item 18 the other equipment carried or other capabilities, preceded by NAV/, COM/, and/or DAT/ as appropriate. Exemptions for RNAV, 8.33 kHz, and CPDLC are to be indicated by inserting the letter Z in item 10a and then inserting the appropriate descriptors in item 18 as detailed in the IFPS Users Manual: a. insert RNAVX or RNAVINOP as appropriate following NAV/; b. insert EXM833 following COM/; c. insert CPDLCX following DAT/. 6) Information on navigation capability is provided to ATC for clearance and routing purposes.
Other equipment carried or other capabilities (see Note 5) J5 CPDLC FANS 1/A SATCOM (INMARSAT) Z J6 CPDLC FANS 1/A SATCOM (MTSAT) Any alphanumeric characters not indicated above are reserved. 1) If the letter S is used, standard equipment is considered to be VHF RTF, VOR and ILS, unless another combination is prescribed by the appropriate ATS authority. 2) If the letter G is used, the types of external GNSS augmentation, if any, are specified in item 18 following the indicator NAV/ and separated by a space. 3) See RTCA/EUROCAE interoperability requirements standard for ATN Baseline 1 (ATN B1 INTEROP Standard DO- 280B/ED-110B) for data link services air traffic control clearance and information/air traffic control communications management/ air traffic control microphone check. 4) If the letter R is used, the performance based navigation levels that can be met shall be specified in item 18 following the indicator PBN/. Guidance material on the application of performance based navigation to a specific route segment, route or area is contained in the Performance Based Navigation Manual (Doc 9613). 5) If the letter Z is used, specify in item 18 the other equipment carried or other capabilities, preceded by NAV/, COM/, and/or DAT/ as appropriate. Exemptions for RNAV, 8.33 kHz, and CPDLC are to be indicated by inserting the letter Z in item 10a and then inserting the appropriate descriptors in item 18 as detailed in the IFPS Users Manual: a. insert RNAVX or RNAVINOP as appropriate following NAV/; b. insert EXM833 following COM/; c. insert CPDLCX following DAT/. 6) Information on navigation capability is provided to ATC for clearance and routing purposes.
The following provisions are applicable to item 10b (surveillance equipment and capabilities). Insert the following letters: N if no surveillance equipment for the route to be flown is carried, or the equipment is unserviceable, or one or more of the following descriptors, to a maximum of 20 characters, to describe the serviceable surveillance equipment and/or capabilities on board: SSR Modes A and C A Transponder — Mode A (4 digits — 4096 codes) C Transponder — Mode A (4 digits — 4096 codes) and Mode C SSR Mode S Note: Enhanced surveillance capability is the ability of the aircraft to down-link aircraft derived data via a Mode S transponder. E Transponder — Mode S, including aircraft identification, pressure-altitude and extended squitter (ADS-B) capability H Transponder — Mode S, including aircraft identification, pressure-altitude and enhanced surveillance capability I Transponder — Mode S, including aircraft identification, but no pressure-altitude capability including aircraft identification, pressure-altitude, extended squitter (ADS-B) and enhanced surveillance capability L Transponder — Mode S, P Transponder — Mode S, including pressure-altitude, but no aircraft identification capability S Transponder — Mode S, including both pressure altitude and aircraft identification capability X Transponder — Mode S with neither aircraft identification nor pressure-altitude capability ADS-B B1 ADS-B with dedicated 1090 MHz ADS-B "out" capability B2 ADS-B with dedicated 1090 MHz ADS-B "out" and "in" capability U1 ADS-B "out" capability using UAT U2 ADS-B "out" and "in" capability using UAT V1 ADS-B "out" capability using VDL Mode 4 V2 ADS-B "out" and "in" capability using VDL Mode 4 ADS-C D1 ADS-C with FANS 1/A capabilities G1 ADS-C with ATN capabilities Any alphanumeric characters not indicated above are reserved. Example: ADE3RV/HB2U2V2G1. Note: Additional surveillance application should be listed in item 18 following the indicator SUR/.
Posts: 8.3K,
Visits: 10K
SkyDemon 2.4.6, released today, contains the new NAV/COM equipment codes to be compatible with the FPL 2012 changes. Other aspects of our flightplan generation engine were already compliant.
There is no benefit to specifing "S" for standard equipment in SkyDemon, you just pick what you have and don't have to worry about what is included in "standard" equipment. SkyDemon will convert your selections to an "S" where appropriate.
Visits: 1.6K
Tim, Any chance of updating the "Larest News" Section in the Homepage when an early opportunity arises so that the community of flyers are all advised of the latest release? Many thanks to all members of the SD Team.
Very Newbytheway
DurhamTeaseAirport
Visits: 1.6K
On a different note can the SD Team advise as to when subscribers can update their iPAD SD safely. I myself has been holding out, considering the bugs encountered in the version released a few weeks ago.
Very Newbytheway
DurhamTeaseAirport
Group: Moderators
Visits: 4.9K
Hi It has been stable for weeks.
Visits: 1.6K
Thanks Steve. Would it be appropriate to add this bit of info eg: Stable with the description in the SD Home page or subsequent descriptive page? Thanks again.
Very Newbytheway
DurhamTeaseAirport
