SkyDemon Flight Planning
iPad Waypoint Importing
kevgleeson
kevgleeson
posted 7/31/2012 3:40:55 AM
Visits: 89
Trying to import my user waypoints from SD on my PC using the correctly named waypoint gpx file into the iPad SD documents folder but nothing shows up on the iPad. If I create an iPad user waypoint then that's fine and can be viewed, edited etc. but none of the imported user waypoints show.
KevG
posted 7/31/2012 11:33:02 AM
Posts: 8.2K,
Visits: 9.7K
It sounds like the required step of terminating and restarting the SkyDemon app may not have been followed.
dryfly52
dryfly52
posted 7/31/2012 1:43:05 PM
Visits: 45
Yes i did that too. In fact I did a 'cold restart' of the iPad. Curiously the export/import worked prior to the recent SD version change.
regards.
kevgleeson
HI, I have exactly the same problem! OK, after further digging...
dryfly52
7/31/2012 9:48:24 AM
It sounds like the required step of terminating and restarting the...
Hi Tim, Yes i did that too. In fact I did a 'cold restart' of the...
dryfly52
The only requirements to the waypoint loading are that the...
8/1/2012 10:18:36 AM
Hi Tim, I'll send you the waypoints file. I've followed all...
kevgleeson
8/2/2012 9:44:29 AM
Hi Tim, i've got the same problem - is there any solution yet....
Robert
8/15/2012 8:57:18 AM
Once you have fully closed and re-opened the app, you may not see the...
Rob Hart
8/15/2012 2:40:41 PM
