Winds aloft & cruise altitude setting
Posts: 8.1K, Visits: 9.3K
The wind arrows shown on the main map are for one altitude only, so they won't change if you just change the level for one leg of your route. If you set the "main" level for your route (in the Flight Details window) that will update the level for which the wind arrows display data.
Posts: 587, Visits: 28K
Tim,
Back to this one again - on an iPad using the latest build.
I'm finding the wind arrows to be somewhat hit and miss when it comes to the altitude they relate to.
I'm currently planning a demo route from Welshpool to Tatenhill at 5000'. The wind arrows are displayed as per 700' as that was the planned altitude for a previous route, which was saved and then scrubbed via 'Start again'.
Changing the planned level by dragging on the virtual radar does not dynamically adjust the level of the wind arrows displayed; you have to kill the app and restart it to force to to do that. Not very elegant!
I may be wrong, but I'm sure at one point it behaved better than this.
It's a system default for a new route.
AnglianAV8R
AnglianAV8R
Posts: 68, Visits: 295
Ok, beginning to make sense of it.
I set up a route and then open the virtual radar and change cruise levels to my requirements and 'save'
Then the winds aloft are given for my selected altitude enroute.
What I'm wondering is whether the initial 3000ft is a system default or, something I've set up in the dim and distant past? If it's me, I'd like to set the default at 2000ft.
By default it'll reflect whatever you've set as the cruise altitude for your flight.
AnglianAV8R
AnglianAV8R
Yes,been doing that.
However, if I simply look at the chart before planning a route and click to show wind data, it gives winds at 3000ft. So, is that a system default or am I able to reset to, say, 1000ft ?
pink leader
pink leader
Posts: 518, Visits: 2K
What I think you do is as follows.
Plan a route on PC.
Bring up the weather window.
Move the height and time sliders and you will see wind speed & direction change as you slide.
D
AnglianAV8R
AnglianAV8R
I have my system running on an assumption of every flight being flown at 3000ft. As a consequence, I presume, the winds aloft are also for 3000ft.
Now I'm struggling to find the right button(s) to press and set it at 1000ft.
Somebody please remind this numpty Smile
