Practice Flight Planning for Olympics
Thomas Jensen
Thomas Jensen
Too Much Forum (844 reputation)Too Much Forum (844 reputation)Too Much Forum (844 reputation)Too Much Forum (844 reputation)Too Much Forum (844 reputation)Too Much Forum (844 reputation)Too Much Forum (844 reputation)Too Much Forum (844 reputation)Too Much Forum (844 reputation)
Posts: 9, Visits: 11
There are many pilots who are worried about filing flight plans during the Olympic air space restrictions. As far as I understand SD will open for the flight planning and making it free during the Olympics, in the SD light, which is absolutely brilliant.
I would like to know if there is a chance of having a dummy olympic SD light "sandbox" for many pilots to get used to the new:
1) Airspace Restrictions (R112 in particular)
2) File a flight plan (many are not comfortable with this bit)
3) Get an "Approval Number" (and remember it)
4) Get to grips with the boundary crossing location and crossing time (+/- 30 min) issues
5) Calculate back in time to determine when you release the breaks in order to be on time (with all the things that can go wrong)
6) Calculate when to turn the nose homewards, when "just having some general fun" outside the R112 zone, in order to hit the boundary location on time and avoid a serious diversion...
Even if the FP error checking is not perfect and the Approval Number is just a dummy number, it will give pilots confidence in advance of the "file a flight plan day" which next is on the 5-6 May.
This practice would also generate some more user feedback and give everyone a bit more peace of mind.
Maybe others have some thoughts or better ideas on this subject, avoiding too many staying on the ground!?
Posts: 7.8K, Visits: 8.4K
SkyDemon Light is currently accepting Olympic flightplan submissions for the test weekend, and is showing the restricted and controlled airspace that will be active during the period of the Olympics.
Dave182
Dave182
Too Much Forum (209 reputation)Too Much Forum (209 reputation)Too Much Forum (209 reputation)Too Much Forum (209 reputation)Too Much Forum (209 reputation)Too Much Forum (209 reputation)Too Much Forum (209 reputation)Too Much Forum (209 reputation)Too Much Forum (209 reputation)
Posts: 1, Visits: 6
Will we be able to file Olympic flight plans from the full version of SD or only from SD-light?
I know the test is only on SD-light so my question is for the real event.
Dave182
The full version of SkyDemon Plan allows you to enter additional addressees and custom remarks, so yes, you certainly can.
skyman
skyman
Too Much Forum (231 reputation)Too Much Forum (231 reputation)Too Much Forum (231 reputation)Too Much Forum (231 reputation)Too Much Forum (231 reputation)Too Much Forum (231 reputation)Too Much Forum (231 reputation)Too Much Forum (231 reputation)Too Much Forum (231 reputation)
Posts: 1, Visits: 7
Do the normal charges apply to these practice flight plans???
G-OIBM
G-OIBM
Posts: 71, Visits: 946
Will filing of flight plans during the Olympic period be free for all versions of SD and not only the lightg version on-line?
Hugh
Hugh
G-OIBM
Commander 114
RossWaddams
RossWaddams
Posts: 5, Visits: 11
It's the Olympics practice weekend and SkyDemon Light is showing the Restricted Area and allowing free FPL filing. So far, so good.
But I have the full version of SkyDemon which isn't showing the Restricted Area and is using up my paid-for FPL credits when I file a practice FPL!
RossWaddams
RossWaddams
See post above and forgive a Newbie! - the Restricted Area IS shown on the full version of SkyDemon. Der.
Ronm
Ronm
Too Much Forum (320 reputation)Too Much Forum (320 reputation)Too Much Forum (320 reputation)Too Much Forum (320 reputation)Too Much Forum (320 reputation)Too Much Forum (320 reputation)Too Much Forum (320 reputation)Too Much Forum (320 reputation)Too Much Forum (320 reputation)
Posts: 2, Visits: 10
Which field on the SD flightplan is equivalent to Field 18 on the AFPEx form? I am running SD full version and on I-pad. I can only see 1 field for "remarks" on the SD version which looks to me like it is in the area for additional survival info. Is this the one to put in contact details for the approval no?
My brief experience this morning was to file a test only, so wanted to put in EGGOLYMP only but couldn't see how to delete the automatically generated addresses. I put a remark in that it was a test flight plan. Received an email from SD to say it had been filed with the auto generated addresses but did not include EGGOLYMP - I assume that it did go there. Cancelled the plan and got a similar email confirmation. Therefore phoned ATLAS control to confirm cancellation just in case.
The main point I see is that normally, I wouldn't want to delete the auto generated addresses, so not really concerned about that, but if a plan is cancelled, does SD also automatically cancel with the EGGOLYMP address even though the confirmation email to me doesn't include it?
Ron
RossWaddams
RossWaddams
I can't claim to be an expert but I have just had an Olympics FPL accepted (after two failures on AFPEx and one on SkyDemon) - Yippee.
SkyDemon has a blank box labelled "Other". That's where all my RMK/'s and contact number went.
As for addressing, I clicked the box "Addressing..." and entered EGGOLYMP in "Extra Addresses". This worked fine for me - I just accepted that the automatic addressees would receive a copy too but would then read the "RMK/OLYMPIC TEST FPL PLEASE IGNORE". After all, this was stated in the Airspace & Safety Initiative guidance document for just this purpose. No-one's phoned me up to complain anyway.
