How to Download and Use Aircraft Files
Posts: 8.1K, Visits: 9.2K
You need to be logged in to this forum in order to download files posted here (unfortunately).
In your personal documents folder there should be a SkyDemon folder. Within that, there should be an Aircraft folder. Just create it if it's not there. Save your aircraft in that folder, ensuring your browser does not change the file extension (it should be .aircraft).
caped123
caped123
Posts: 3, Visits: 38
If using Windows 7, open a folder.
At the top right where it says Organize, click and you will get a drop down menu.
Select Folder and Search options
A window with 3 tabs will open.
Select View
About half way down you will see Hide extensions for known file types
Click the box to remove the tick, then Apply - bottom right followed by OK - bottom left to close the window.
When you re-open the SD folder then Aircraft folder, you will see the aircraft type followed by the extension e.g. Cessna.xxx
Right click this and select Rename.
Change .xxx to .aircraft
Windows will warn you about changing the file extension. Click to disregard the warning
Hope this is of some help
Eddie
Tim Dawson - 4/5/2011 3:52:05 PM
frose - 4/13/2012 4:42:40 PM
caped123 - 4/14/2012 10:46:15 PM
frose - 4/19/2012 2:03:34 PM
caped123 - 4/20/2012 6:45:11 PM
Peterserle - 4/20/2012 9:53:58 PM
telhek - 6/29/2012 4:43:32 PM
telhek - 6/29/2012 5:38:10 PM
pwampach - 9/24/2012 10:18:41 AM
             yes I would like to know that too!
andyth - 10/27/2012 3:10:59 PM
                 me too:)
IstvanToth - 10/31/2012 1:01:12 PM
neilmurg - 4/4/2015 4:18:57 PM
                     + x [quote] [b] neilmurg - 4/4/2015 4:18:57 PM [/b] If...
jmoylan69 - 9/5/2016 2:14:10 AM
Flare! - 1/8/2013 9:10:53 AM
nje - 1/8/2013 1:29:48 PM
macninja - 11/27/2014 7:59:02 PM
Rotorman - 2/6/2017 4:13:34 PM
email@oliverspencer.com - 2/20/2017 2:57:27 PM
tnowak - 2/21/2017 8:29:15 AM
