French frequencies
donkey89
donkey89
Too Much Forum (706 reputation)Too Much Forum (706 reputation)Too Much Forum (706 reputation)Too Much Forum (706 reputation)Too Much Forum (706 reputation)Too Much Forum (706 reputation)Too Much Forum (706 reputation)Too Much Forum (706 reputation)Too Much Forum (706 reputation)
Posts: 6, Visits: 58
Hi
Are frequencies updated as and when they change?
I have noticed a few inaccuracies particularly in the Rennes area and around Lannion which have changed well over a year ago.
Just wondering if the actual airspace data is also out of date or whether they are updated independently of each other.
Miichèle
Miich&#232le
Too Much Forum (211 reputation)Too Much Forum (211 reputation)Too Much Forum (211 reputation)Too Much Forum (211 reputation)Too Much Forum (211 reputation)Too Much Forum (211 reputation)Too Much Forum (211 reputation)Too Much Forum (211 reputation)Too Much Forum (211 reputation)
Posts: 2, Visits: 2
To all,
I find this question particularly pertinent and important. If we are to use Skydemon to plan flights, we must rely on the data being accurate. If airspaces are innacurat nor updated and frequencies are out dated, then all the data which Skydemon provides must be double checked item by item. This means that flight planning on original updated official documents would take no longer than doing it with Skydemon plus double checking.
I know that Skydemon says that they are not commited to accuracy and that it's up to the pilot to ascertain that the flight plan he will use has been properly checked however Skydemon should provide a reasonable level of accuracy. Donket89 does point out some rather serious faults.
I do hope that Skydemon will respond quickly to this post as the original post is more than 10 days old with no response.
Thanks,
Michèle
