Direct to... IFR Waypoints
n6zp
n6zp
posted 2/24/2012 8:28:20 PM
Visits: 20
When using the "Direct to" function on the iPad it is only possible to select airfields. It would be great if it would be possible to select IFR waypoint (and possibly VFR reporting points), which are in the vicinity of the planned route.
T67M
T67M
posted 3/21/2012 10:53:49 PM
Visits: 3.2K
My suggestion for continuing the route after going "direct-to" would be one of the following:
1) Continue from the next waypoint at the time the direct-to was instigated (i.e. insert direct-to on current leg)
2) Continue from the nearest waypoint to the direct-to destination (continue to <next waypoint>
3) Continue from the route waypoint which gives the shortest total distance between the direct-to destination and the final destination (continue route to destination)
If I had to choose just one of these options, my preference would be for option 3, however a choice of "insert <direct-to> on current leg", "continue to <next waypoint>" or "continue route to destination" when making the direct-to would be nirvana.
Cheers,
T67M
n6zp
I mentioned this at the NEC and asked if they could look into it. It...
Alan Walker
2/24/2012 9:28:21 PM
I figured out a way to fly direct to a Waypoint, but it is rather...
n6zp
2/25/2012 10:34:24 AM
When you perform a "direct to" operation, is it not your intention...
2/27/2012 2:24:09 PM
That is the general idea Tim. Treat it as a 'get out of jail' move...
Alan Walker
2/27/2012 4:00:27 PM
My comment was primarily in response to the previous poster who...
2/27/2012 4:24:40 PM
I am not particularly close to SD Base Ops but happy to help out...
Alan Walker
2/27/2012 5:17:36 PM
My suggestion for continuing the route after going "direct-to" would...
T67M
