Direct to... IFR Waypoints
http://forums.skydemon.aero/Topic5079.aspx
By n6zp - 2/24/2012 8:28:20 PM
When using the "Direct to" function on the iPad it is only possible to select airfields. It would be great if it would be possible to select IFR waypoint (and possibly VFR reporting points), which are in the vicinity of the planned route.
By T67M - 3/21/2012 10:53:49 PM
My suggestion for continuing the route after going "direct-to" would be one of the following:
1) Continue from the next waypoint at the time the direct-to was instigated (i.e. insert direct-to on current leg)
2) Continue from the nearest waypoint to the direct-to destination (continue to <next waypoint>Wink
3) Continue from the route waypoint which gives the shortest total distance between the direct-to destination and the final destination (continue route to destination)
If I had to choose just one of these options, my preference would be for option 3, however a choice of "insert <direct-to> on current leg", "continue to <next waypoint>" or "continue route to destination" when making the direct-to would be nirvana.
Cheers,
T67M
