Failed to export route to Garmin Pilot III
royt
royt
Too Much Forum (721 reputation)Too Much Forum (721 reputation)Too Much Forum (721 reputation)Too Much Forum (721 reputation)Too Much Forum (721 reputation)Too Much Forum (721 reputation)Too Much Forum (721 reputation)Too Much Forum (721 reputation)Too Much Forum (721 reputation)
Posts: 5, Visits: 29
I have tried to export a route from SkyDemon to my Garmin Pilot III and although the route appears to transfer (as the route name appears in the Pilot III's route list), just after pressing enter on the Garmin to acknowledge data transfer is complete, I get the message "Route Waypoint Deleted" on the Garmin. Despite SkyDemon indicating that the route has been successfully exported to my device, the waypoint list in that route in the Garmin is empty.
Going to Tannkosh so need the Pilot III and want to shift from Jeppesen (which works fine) to SkyDemon
pink leader
pink leader
Posts: 518, Visits: 2K
What method did you use to export? Sync or Send to connected device.
I have had some flaky transfers.
Did you use the filename of the saved route or did you rename?
Try various combinations & see if it works.
D
Rowan
Rowan
Posts: 23, Visits: 204
Although I have no problem exporting routes to my Garmin 96C, SD doesn’t appear to work well with other Garmin software (eg. MapSource) or other (Garmin) GPS units. The work around I have been using is to use the programe EasyGPS as an intermediate step. It can open the SD GPX files, and save them in a form that other programmes can use, as well as exporting directly to other GPSs – not ideal, and care is needed with coordinate formats.
royt
royt
I have tried all methods available and even connected to the PC directly via serial rather than via a USB/Serial cable but still no route with any waypoints.
