Flight Plans for Formations or Small Groups of Aircraft
Peter Robertson
Peter Robertson
Posts: 49, Visits: 147
Hi, Tim / Rob / Hannah,
I have been looking for information on submitting flight plans for (loose) formations, or small groups of aircraft (for example for Channel crossings).
The 'Show Full (Flightplan) Form' tab on the 'Prepare Flightplan' screen allows selection of the Number (of aircraft) to be entered on the next page. This number is already set to '1' so presumably the number required is the total number in the group or formation. Changing this number automatically brings up a header note advising that 'The numbers and types of aircraft in the formation must be specified in the 'Extra Information' box with the TYP/ keyword', but neither the app nor the manual make any reference as to HOW to add the additional aircraft. The last time I tried to use this feature (for a simple 'pair' of flexwings) it failed - presumably due to a syntax error of some sort, but I had no way of knowing why it was failing, so had to resort to individual flight plans for each aircraft.
Following a re-read of the latest Manual and a Forum search this afternoon, the only information I can find is a reference to adding the (additional) registrations to the 'EXTRA INFORMATION' section by using  'TYP/', (already covered by the header message) but again, no detail as to exactly how to do this or whether / how to advise if any of them are of a different type to the primary aircraft. An example in the flight planning section of the SD Manual would allow you to clarify these points and also show of the correct syntax and would help users massively.
Best Regards as always
Peter Robertson
Posts: 659, Visits: 32K
Peter Robertson - 2/11/2026 5:34:22 PM
Peter Robertson
The rules for completion of FPLs are nicely summarised here.
The relevant bit is -
NUMBER AND TYPE OF AIRCRAFT AND WAKE TURBULENCE CATEGORY
Insert number of aircraft, if more than one (1 or 2 characters) followed by type of aircraft (2 to 4 characters).
The type of aircraft is indicated by the manufacturer’s designator. If no such designator has been assigned, or in the case of formation flights comprising more than one type, insert “ZZZZ” and specify the number(s) and type(s) of aircraft in Item 18 (see below) preceded by “TYP/” (up to 60 characters can be put, for example: TYP/3C182 2C172).
There's an interesting question here of how far SkyDemon should go when it comes to teaching people how to file flightplans. We go a long way to making the process easy, but we don't cover anywhere near all the niche cases with a friendly UI, instead expecting people who want to file flightplans to consult the documentation on flightplans (rather than our own documentation).
I certainly appreciate that some things are more niche than others, but at present, adding a friendlier UI to facilitate filing formation flightplans is quite low on our priority list I'm afraid. Perhaps we'll get there someday. We certainly appreciate the feedback!
