Flightplan. Filing and closing the flightplan.
publicom
Too Much Forum (484 reputation)Too Much Forum (484 reputation)Too Much Forum (484 reputation)Too Much Forum (484 reputation)Too Much Forum (484 reputation)Too Much Forum (484 reputation)Too Much Forum (484 reputation)Too Much Forum (484 reputation)Too Much Forum (484 reputation)
Posts: 39, Visits: 116
Aint1 - 8/22/2025 3:06:55 PM
After editing my route and selecting my aircraft from my aircraft library in SkyDemon, I filed a flightplan. However, in the confirmation email I received from Skydemon, the callsign listed was that of a different aircraft from my library. Has anyone else experienced this issue?
Your Question is not related to the topic.
Aint1
A
Posts: 2, Visits: 0
Indeed. It's just that almost nobody has asked us for this feature over the years, so we have never written it.
publicom
Tim Dawson - 3/21/2024 10:13:00 AM
I think SkyDemon only offers the option to send a message saying you have arrived at your original planned destination. If you have diverted, you'll need to use another method to advise everyone.
I understand. But why this limitation? As a suggestion: The ARR-Message just needs to transmit the Code of the actual airport in addition.
publicom
Tim Dawson - 9/14/2017 10:21:42 AM
You'll get a Close option if the flightplan can be closed (i.e. you have just arrived at your destination).
Just to clarify:  Does this only work if arrived at the planned destination or alternate(s), or also if I diverted to another field?
MarkN
M
Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)
Posts: 1, Visits: 0
Hi Tim. The options available are Delay / Cancel / View. There is no Close function showing, either within the app or on the web. Tks, Mark.
Henny Joosten
Henny Joosten
Posts: 48, Visits: 349
Hello Tim,It is in the received email link indeed.
What I ment is closing the flightplan directly with the (android)phone (note 2/3) on the same and easy way as creating and filing the flightplan Tim.
A one touch button after landing. The flightplan info is still available so it should be possible I think.
Kind regards
Hendrik
Edited 5/13/2014 9:40:22 AM by Hendrik
Henny Joosten
Henny Joosten
Hello Tim,
Thanks for your reply. I think it is a great value that your users think with you to improve your great software so please be aware about that.
Just like you ask your users on Facebook I think.
The idea came from me and my friend and we just didn't see this option. Perhaps we are not using all the options enough or it's not documented enough?
We are using SD on our android phones.
I'm going to check this and will respond to you.
Thanks.
