Posts: 8.2K,
Visits: 9.7K
The message is triggered when logging stops. If SkyDemon has started your log automatically on takeoff, as it does for many people, it'll therefore appear on landing. If you've started logging manually then it should appear when you then stop logging manually. If you just go straight for Stop Navigating you'd probably never see it, because such banners only appear in navigation mode.
