Garmin SL-40 interface
Mikael Markow
M
Posts: 2, Visits: 29
Tim Dawson - 6/24/2024 11:24:20 AM
We are hoping to support this in our next major release. Is anyone on this thread interested in testing?
Yes, I am interested in testing it.
\Mikael
The next release is nearly out, so the testing phase is pretty much over. You're welcome to try the beta though, at our beta page.
Mikael Markow
M
Tim Dawson - 8/8/2024 9:18:20 AM
Tim,
I found this thread when googling for information of Bluetooth to aviation radio apps and hardware, since I just started a project making hardware and an app for this. (I use SD since 5 years though).
This project was inspired by the f.u.n.k.e. app with hardware suggestions.
It is ok but sort of limited and outdated. So my plan is to make modern hardware and a better app for transferring frequencies to aviation radios.
I run a small business in electronic design since many years. Have made electronics for all kinds of stuff, including for the Swedish air-force.
I will make sure that this hardware will also work with SD.
\Mikael
Mikael Markow
M
Posts: 10, Visits: 0
Mikael Markow - 8/11/2024 7:45:38 PM
Tim,
\Mikael
Hello again Tim,
Now my product is finished and available.
I can send you a free sample if you give me your snail mail address.
More info in the other thread.
\Mikael
http://www.utronix.se/Aviation
That's great. We've seen a few of these come on to the market in the last month since we introduced support for transferring frequencies. No need to send us one, but by all means come and show us at Friedrichshafen.
Mikael Markow
M
Tim Dawson - 3/25/2025 11:03:49 AM
Ok, I will not be at Friedrichshafen but you will see it sooner or later somewhere.
As far as I know this is the first device with firmware application written specific for this, as I mentioned in August..
As far as I know this is the first device with the electronics and PCB designed specific for this.
As far as I know this is the first device designed to handle the harsh environment in an aircraft.
I of course think it is superior, for good reasons ;-)
Next week the RS422 version will be available too.
It is based nrf52832 with Nordic semiconductors Bluetooth stack and Zephyr RTOS and molded in urethane to protect from environment. It can have fw updated via Bluetooth.
Edited 3/25/2025 10:29:40 PM by Mikael Markow
Mikael Markow
M
Tim,
For your information, some technical details:
Aviation Companion uses the random 128-bit Bluetooth service UUID:
(0xe019ffe0, 0x1c81, 0x4940, 0xa64a, 0x739cfc3391b0)
This random 128-bit UUIDs may be used by anyone in Bluetooth devices.
Aviation Companion is also, for use with SD, backwards compatible with the 16-bit UUIDs 0xffe0/e1/e2 even though these are not allowed to be used in the Bluetooth standard.
