By vovo - 12/18/2021 4:09:31 PM
Today, I installed XCSoar on my tablet, because I think controlling of the radio via tablet is very convinient.XCSoar has an implemention for this feature. I like to use skydemon for when flying with a motor, but Xcsoar is capable of controlling the radio. So, currently I am unsure what to use.
If this feature was more known, I am sure everyone will like it. The biggest issue is the complicated installation and configuration of the RS232 connection. You will need a BT -> RS232 Adapter or something like that.
By mxb - 3/7/2018 9:52:50 PM
What about supporting (with appropriate devices) the Garmin SL-40 protocol, which is able to set frequency/memory of the radio getting the data form the GPS system?
I've tested this feature on seeral different acft, and I think it is an extremely interesting feature: one time you get acquainted to it, it's hard to come back to setup frequencies by hand (and sometimes also setting the wrong ones...)
Not only Garmin system does support this feature: for example the Trig radios (made in UK...) may be driven in such way.
What do you think about?
Regards,
mxb
By Mikael - 8/7/2024 3:07:47 PM
+xWe are hoping to support this in our next major release. Is anyone on this thread interested in testing? Yes, I am interested in testing it. \Mikael
By Tim Dawson - 8/8/2024 9:18:20 AM
The next release is nearly out, so the testing phase is pretty much over. You're welcome to try the beta though, at our beta page.
By Mikael - 8/11/2024 7:45:38 PM
+xThe next release is nearly out, so the testing phase is pretty much over. You're welcome to try the beta though, at our beta page.
Tim, I found this thread when googling for information of Bluetooth to aviation radio apps and hardware, since I just started a project making hardware and an app for this. (I use SD since 5 years though). This project was inspired by the f.u.n.k.e. app with hardware suggestions. It is ok but sort of limited and outdated. So my plan is to make modern hardware and a better app for transferring frequencies to aviation radios.
I run a small business in electronic design since many years. Have made electronics for all kinds of stuff, including for the Swedish air-force.
I will make sure that this hardware will also work with SD.
\Mikael
By Mikael Markow - 3/20/2025 9:23:19 PM
+x+xThe next release is nearly out, so the testing phase is pretty much over. You're welcome to try the beta though, at our beta page.
Tim, I found this thread when googling for information of Bluetooth to aviation radio apps and hardware, since I just started a project making hardware and an app for this. (I use SD since 5 years though). This project was inspired by the f.u.n.k.e. app with hardware suggestions. It is ok but sort of limited and outdated. So my plan is to make modern hardware and a better app for transferring frequencies to aviation radios. I run a small business in electronic design since many years. Have made electronics for all kinds of stuff, including for the Swedish air-force. I will make sure that this hardware will also work with SD. \Mikael Hello again Tim,
Now my product is finished and available. I can send you a free sample if you give me your snail mail address.
More info in the other thread.
\Mikael http://www.utronix.se/Aviation
By Tim Dawson - 3/25/2025 11:03:49 AM
That's great. We've seen a few of these come on to the market in the last month since we introduced support for transferring frequencies. No need to send us one, but by all means come and show us at Friedrichshafen.
By Mikael Markow - 3/25/2025 10:23:07 PM
+xThat's great. We've seen a few of these come on to the market in the last month since we introduced support for transferring frequencies. No need to send us one, but by all means come and show us at Friedrichshafen. Ok, I will not be at Friedrichshafen but you will see it sooner or later somewhere.
As far as I know this is the first device with firmware application written specific for this, as I mentioned in August.. As far as I know this is the first device with the electronics and PCB designed specific for this. As far as I know this is the first device designed to handle the harsh environment in an aircraft.
I of course think it is superior, for good reasons ;-)
Next week the RS422 version will be available too.
It is based nrf52832 with Nordic semiconductors Bluetooth stack and Zephyr RTOS and molded in urethane to protect from environment. It can have fw updated via Bluetooth.
By Mikael Markow - 4/9/2025 6:58:27 AM
Tim, For your information, some technical details:
Aviation Companion uses the random 128-bit Bluetooth service UUID: (0xe019ffe0, 0x1c81, 0x4940, 0xa64a, 0x739cfc3391b0) This random 128-bit UUIDs may be used by anyone in Bluetooth devices.
Aviation Companion is also, for use with SD, backwards compatible with the 16-bit UUIDs 0xffe0/e1/e2 even though these are not allowed to be used in the Bluetooth standard.
By Tim Dawson - 6/24/2024 11:24:20 AM
