French instrument charts missing?
Yves Dormoy
Y
Posts: 7, Visits: 2
Yves Dormoy - 2/20/2025 7:02:18 PM
Tim Dawson - 2/20/2025 2:43:29 PM
In fairness, my post that you were responding to was 8 years old.
Sadly in the intervening time, the French authorities are still not publishing their AD charts in separate documents via the Eurocontrol EAD database, which is the database that feeds into SkyDemon. However we have since implemented tools to incorporate documents from other sources, and since you pointed out there is a convenient eAIP download from the SIA incorporating the plates, I have created a tool to import them into SkyDemon.
Within a few hours you should see all these IAC plates in SkyDemon and within a few days we will have georeferenced them for use.
Thanks for letting us know!
Yes Tim, you're great, french IFR georeferenced plates are there and work very well. Coupled with RS232 Blutooth output, SD is definitely the very best ! Many many thanks.
Unfortunately, the French have not yet posted the updated plates for the forthcoming AIRAC update, which is in 2 days. If these documents are not posted well in advance, it may not be sustainable for us to load them into our system and do the georeferencing work.
