QNH on Radio Tab while flying
BS
B
Too Much Forum (239 reputation)Too Much Forum (239 reputation)Too Much Forum (239 reputation)Too Much Forum (239 reputation)Too Much Forum (239 reputation)Too Much Forum (239 reputation)Too Much Forum (239 reputation)Too Much Forum (239 reputation)Too Much Forum (239 reputation)
Posts: 32, Visits: 485
In the manual it states: "At the top of the Radio tab you’ll also see a pressure setting (QNH) taken from the nearest airfield with a recent METAR bulletin."
Presumably if I'm flying low enough to get a mobile signal then this will be updated (yes have a cellular iPad).
However, if above say 5,000' in Wales, does SD keep a record of airfields on my route and populate the QNH field as I go along but with data that will only be relevant at the time of last contact with the mobile phone network? Agreed QNH shouldn't change massively during a flight but just curious.
Posts: 659, Visits: 32K
BS - 6/15/2024 8:22:26 PM
At 5000' over Wales, you'd probably receive the ATIS for Hawarden, Cardiff and Birmingham (and probably Valley and Gloucester as well) Just take an average across the closest.
BS
B
grahamb - 6/16/2024 11:08:04 AM
Agreed there are other options to get QNH, just wondering how SD populates the QNH field if out of mobile coverage.
I suspect we will show you the data from the latest (and closest) METAR, but only if it was within the last hour or similar length of time.
Tim Dawson - 6/17/2024 9:54:46 AM
And from playing with the simulator, it seems to only display the nearest (and most recent) within 50nm.
