Mixed (VFR / IFR) Mode should show VFR and IFR symbols
ljkenny
l
Forum Member (36 reputation)Forum Member (36 reputation)Forum Member (36 reputation)Forum Member (36 reputation)Forum Member (36 reputation)Forum Member (36 reputation)Forum Member (36 reputation)Forum Member (36 reputation)Forum Member (36 reputation)
Posts: 4, Visits: 13
NB: This post could have easily lived in Planning, Navigation or Suggestions - I choose here arbitrarily.
- When switching from VFR to Mixed mode, the map stays in VFR mode (no IFR reporting points).
When switching from IFR to Mixed mode, the map says in IFR mode (no Airspace boundaries/info).
As it stands, when planning an IFR flight, I have to plan in VFR mode to ensure I'm not infringing, then switch to IFR mode to drag turning points onto a local IFR reporting points.  The same goes when en route; normally I'd fly in VFR mode, again to avoid infringing, then if any changes are required, I have to flip to IFR mode, make the route changes, then back again.
Ideally, at least for me, it would be much better if Mixed mode would show both Airspaces and IFR reporting points.
marioair
m
Posts: 158, Visits: 1
Thanks.
Hoping people read this and like the post Smile
