Waypoint list files
giannisd
giannisd
Too Much Forum (5.4K reputation)Too Much Forum (5.4K reputation)Too Much Forum (5.4K reputation)Too Much Forum (5.4K reputation)Too Much Forum (5.4K reputation)Too Much Forum (5.4K reputation)Too Much Forum (5.4K reputation)Too Much Forum (5.4K reputation)Too Much Forum (5.4K reputation)
Posts: 101, Visits: 189
Tim good day,
Is it possible to create a waypoint file from a list of coordinates instead of creating the waypoints one at a time and downloading the file directly into a specific folder in to the Waypoin Directory?
Example: I need to create a particular area for a glider competition, today I must create a list of waypoints one by one and then join them as if it were a route, it would be much simpler to create a file and download it directly to the iPad from the PC.
I tried to open the Waypoits Dircetory folder, to see inside, but is not possible.....
Surely it would be better to use the Data Creator tool to create a piece of "airspace" describing the area for the competition?
SkyDemon can import waypoints in GPX format, so if you can export them in that format from another tool then that would be a quick way of importing them.
giannisd
giannisd
Tim Dawson - 12/18/2023 11:13:57 AM
From a text list of coordinates can you suggest an application to create a GPX file?
I'm using MAC...
Posts: 663, Visits: 32K
giannisd - 12/18/2023 5:50:00 PM
I'm using MAC...
If you can find a machine on which to load the Windows version of SD, it's really easy editing the XML waypoint files with notepad.
