Missing aerodrome NOTAMs for planned route
arj
a
Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)
Posts: 19, Visits: 79
Hi all,
Not sure how to fix this, but if I plan a route EGKB-EGMD-EGMC-EGKB, then EGMD and EGMC NOTAMs are missing from a standard pre-flight brief (NOTAMs part), EGKB and enroute ones are all there. Am I missing some magic option/button? Using SD for Windows for that.
Thanks a lot!
Posts: 636, Visits: 31K
arj - 6/24/2023 8:42:44 AM
Hi all,
Thanks a lot!
I’m not a NOTAM expert, but AFAIAA some are defined as ‘aerodrome’, and some ‘en-route’. You’ll only see aerodrome ones if SD thinks you are landing there.
If your route was via the overheads, you’ll only see en-route NOTAM for Lydd and Southend; if you select the ‘Land here’ option for them, which effectively breaks your route into three separate flights, you see the aerodrome NOTAM for both ends of each flight when you select it.
Edited 6/25/2023 10:03:39 AM by grahamb
arj
a
grahamb - 6/25/2023 9:53:07 AM
Hi all,
Thanks a lot!
I’m not a NOTAM expert, but AFAIAA some are defined as ‘aerodrome, and some ‘en-route’. You’ll only see aerodrome ones if SD thinks you are landing there.
How do I specify that I land there? I want to keep it as a single route in a PLog for many reasons, but for some reason cannot see the AD NOTAMs.
arj - 6/25/2023 10:06:06 AM
Hi all,
Thanks a lot!
Hover your mouse over the airfield you are using as the intermediate waypoint and select 'Land here'.
It is by design that aerodrome NOTAMs only appear in your planned route NOTAM briefing if you are actually planning to land there.
You can see aerodrome NOTAMs separately, no matter what route you have planned, in the airfields tab.
