help for Radio tab
Markus117
M
Too Much Forum (372 reputation)Too Much Forum (372 reputation)Too Much Forum (372 reputation)Too Much Forum (372 reputation)Too Much Forum (372 reputation)Too Much Forum (372 reputation)Too Much Forum (372 reputation)Too Much Forum (372 reputation)Too Much Forum (372 reputation)
Posts: 23, Visits: 24
Hi.
Why are so few radio frequencies displayed to me? Is this because of the new update? I see only the tower frequencies and Langeninformation.
Greetings Markus
Markus117
M
pgroell
pgroell
Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)
Posts: 102, Visits: 18K
The radio tab is adapting to your route and position, it will update as necessary.
It is not clear what your planned route is but this is quite normal if you planned a small route around EDVI I tried EDVI to EDVA and got the same frequencies as you.
Try planning EDVI to EDPL and you'll get more frequencies in the tab.
Markus117
M
Hallo pgroell,
normally it is also like this. But, I started my flight in Paderborn EDLP. And only 3 frequencies were displayed to me: Paderborn tower, Langen information and the frequency from the destination airport EDVI. ATIS and Paderborn Operations as well as many frequencies were simply not displayed. I hope this is a setting problem from myself. It would be a pity if the radio tab was simplified.
Markus117
M
Markus117
M
Only in the pilotlog can you see the frequencies.
Posts: 8.2K, Visits: 9.8K
The Radio tab isn't designed to duplicate the PLOG, it's designed to show you people (services) you can talk to right now, based on your current position, and within the next 10 minutes of flight based on your trajectory.
Markus117
M
Hello Tim,
thank you very much for your answer. I have included the PLOG only as an example. I just wanted to represent that until recently I have the same amount of frequencies in the radio tab as is indicated in the PLOG.
Can you tell me if I can change this in the settings or is shortened by you on purpose?
Markus117
M
At the departure airport, only minor information is displayed. But at the destination everything is displayed. I would like to be able to see all frequencies at the departure airport. Would this be possible?
Here are some screenshots:
If I fly from Paderborn to Hannover, not all frequencies from Paderborn are displayed. If I turn the flight around and fly from Hannover to Paderborn, now i can see all the frequencies from Paderborn. I would be happy if this is implemented.
Yes, I think that is a reasonable suggestion. However, let's design it right. I presume you would not wish your departure airfield frequencies to be listed once you are getting close to your destination. Therefore, should we only show them when you're on the ground at your departure airfield? Or perhaps within 10 miles of it? As always we appreciate input before we make changes.
