help for Radio tab
Markus117
M
Too Much Forum (488 reputation)Too Much Forum (488 reputation)Too Much Forum (488 reputation)Too Much Forum (488 reputation)Too Much Forum (488 reputation)Too Much Forum (488 reputation)Too Much Forum (488 reputation)Too Much Forum (488 reputation)Too Much Forum (488 reputation)
Posts: 23, Visits: 24
Tim Dawson - 4/5/2022 9:21:15 AM
Yes, I think that is a reasonable suggestion. However, let's design it right. I presume you would not wish your departure airfield frequencies to be listed once you are getting close to your destination. Therefore, should we only show them when you're on the ground at your departure airfield? Or perhaps within 10 miles of it? As always we appreciate input before we make changes.
Hello Tim, that's exactly what I mean. Wink
That would be nice if you could implement this suggestion.
Greetings Markus
Markus117
M
If the frequencies remain displayed within a radius of approx. 10 nm, this would be sufficient. In the case that you want to return to the departure airport, the possibility is also for the safety that the frequencies of the departure airfield are still displayed in a radius of 10 nm.
Consider it done.
