+x Sky Painter - 3/10/2022 5:01:22 PM+x Azam - 3/10/2022 11:42:32 AM+x Sky Painter - 3/10/2022 11:30:50 AM+x Azam - 3/10/2022 7:55:08 AMHi all,I tried looking through the forum for a solution but couldn't find any. I am using the latest version of SD on a Samsung S10 phone and Samsung Galaxy tablet A8. It works on the phone but not on the tablet. It searches for the my position but can't find it and sometimes it just gives me an error message. I've gone through the settings and permissions and it all should work. Any solutions?Hi AzamI'm using SD on a Samsung Galaxy A8 tablet without any problems. Can you explain the nature of your problem in greater detail please? Silly question perhaps, but are you sure that you have Location Services enabled?Hi Mike,Yes of course, I have enabled location services and high accuracy. I have the same settings on my phone. When I press start flying it says "waiting for location data" and nothing happens. When I press the button on the bottom right corner to indicate position it says "location data cannot be obtained". Can I trouble you to attach some screenshots of your settings? Thanks!Hi AzamAre you wanting tablet settings or SD settings? It might be worth going to the Location settings and checking under App Permissions that you have given SD permission to use Location Services.
+x Azam - 3/10/2022 5:13:58 PMHi Mike,Tablet settings I presume. Or do I need to fix any settings in SD? I've checked the permissions and they are all set.
