Stratux
TouchTheSky
T
Posts: 153, Visits: 4.6K
Fliy - 10/28/2024 4:39:20 PM
TouchTheSky - 2/11/2022 1:46:51 PM
KeiXiD - 2/11/2022 12:50:55 PM
This setting was at 12500ft so it should display targets.
One more thought: did you try to enable and use "FLARM Devices" Air Avionics AT-1 as the location source? Did you set the Stratux IP to 192.168.1.1?
Mine is set to 192.168.10.1 and Mode-S-Signals doesn't appear on SD and even I cannot connect via Air Avionics AT-1 (only by GDL 90).
Is the reason for this problem the wrong IP address I have chosen?
Maybe yes but latest Stratux version supports BLE and works nicely with SkyDemon. No WiFi issues any more...
