Stratux
Antoine
A
Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)
Posts: 3, Visits: 1
I work on Raspberry Pi and ADS-B receivers to feed FR24 and Radarvirtuel and yesterday I discovered the Stratux project. I tested it with Foreflight and could see my local traffics Smile. But I'm flying in Europe and I love SD, is there a way to use Stratux signals with SD ? Or stratux's support can be added in addition of Flarm ?
Regards,
Antoine
BJS
B
Too Much Forum (667 reputation)Too Much Forum (667 reputation)Too Much Forum (667 reputation)Too Much Forum (667 reputation)Too Much Forum (667 reputation)Too Much Forum (667 reputation)Too Much Forum (667 reputation)Too Much Forum (667 reputation)Too Much Forum (667 reputation)
Posts: 47, Visits: 149
TouchTheSky - 1/15/2022 4:37:37 PM
Fedko - 1/15/2022 2:30:20 PM
TouchTheSky - 12/17/2021 7:02:06 AM
Fedko - 12/16/2021 8:45:31 PM
Thank you very much @TouchTheSky and @b3nn0 for your answers, it is very clear.
I will go have a look at Github discussion.
While I'm here, I would like to take the opportunity to ask about what is the best way to reduce the OGN Noise.
Looking on the screenshot below, I seem to be suffering from significant range loss: 5.31x. Is there any way to improve this?
Thanks a lot, and happy Holidays to all!
I assume you are using the usual antennas so you may try to move them away from your Pi as it is the source for most of the "noise". A good alternative would be a T style dipole antenna which usually comes with 1-2m cable. Sometimes all metal Pi cases help but then Wifi might become less reliable. Can you post a picture of your Stratux?
Btw, you may consider the Stratux Slack channel where many of us are quite active: Stratux Slack. Besides the "#general" channel there is a particular channel "#stratux-europe-edition".
Thank you for you answer.
I will register in Slack. In the meantime, attached a few pictures. Sorry for the orientations, but for some reason the forum in turning them as it wants...
The Startux is on a GoPro mount, and has large 1090 and 868 antennas. It is mounted on the left side window of a C172  between the door and the panel.
I identified some possible reasons, what do you think?
- the GPS plate is touching the SDR - but I dont really have a solution for that...
- I added a small cooler below the SDRs, as they seem to get hot - do you think that this can have an impact? Should I remove it?
Below the hood, I also have the Dross board with the Baro and AHRS sensor, as well as the off-button. I don't know if these can have any impact on noise?
Thanks!
This seems like a pretty standard Stratux, no immediate concerns. I would not worry too much about the 15dB OGN noise, it can have multiple reasons. Make sure that your antennas are oriented vertically.
and to add some advice - the flat area of the pinkish GPS antenna has to point to the sky to get decent GPS reception ... have seen so many people with no physics understanding at all I can't count any more.
Antoine - 9/1/2016 2:41:23 PM
Sky Painter - 9/1/2016 3:30:16 PM
Antoine - 9/2/2016 6:25:07 AM
Tim Dawson - 9/5/2016 10:29:30 AM
Paul_Sengupta - 12/7/2016 2:55:15 PM
piperpa28 - 1/13/2017 11:43:23 AM
eight10man - 1/27/2017 8:51:35 AM
piperpa28 - 1/27/2017 10:48:19 PM
Paul_Sengupta - 1/29/2017 10:45:28 PM
piperpa28 - 1/30/2017 12:00:31 AM
crablab - 3/31/2017 3:59:23 PM
Paul_Sengupta - 4/15/2017 11:26:45 AM
DavidC - 8/26/2017 6:04:55 PM
ACW20 - 9/15/2017 7:06:54 PM
neubamat - 10/2/2017 4:35:38 PM
Tim Dawson - 10/4/2017 2:48:36 PM
neubamat - 10/4/2017 8:27:16 PM
rg - 10/5/2017 7:42:08 PM
neubamat - 10/6/2017 4:11:06 PM
rg - 10/6/2017 4:15:37 PM
neubamat - 10/6/2017 7:00:56 PM
Telefisch - 10/21/2017 3:53:34 PM
                         Try Setup - Navigation Options - Other Traffic and increase "Show...
neubamat - 10/23/2017 4:44:50 PM
                             I would love if this thread could be kept alive, I'm considering...
Viscab - 10/29/2017 7:31:19 PM
                             Thanks for that Tip, I‌'ll give it a try, next time the weather will...
Telefisch - 10/30/2017 10:12:16 AM
                                 Ok, meanwhile I went flying and was a bit disappointed. I‌ thought,...
Telefisch - 11/7/2017 1:01:45 PM
                                     Have you installed the latest stratux software? And if so have you...
rg - 11/7/2017 1:35:31 PM
                                         Yes, I have installed the MPU9250-BMP280. If Software is at latest...
Telefisch - 11/7/2017 4:42:01 PM
                                         Sorry for coming back to this topic. Can someone confirm that the baro...
TouchTheSky - 4/23/2018 11:34:02 AM
                                             Yes it is.
rg - 4/23/2018 3:28:33 PM
                                                 Is there any particular reason for it?
TouchTheSky - 4/23/2018 4:26:33 PM
                                                     Without it the GDL90 message only includes GPS altitude and Skydemon...
rg - 4/23/2018 4:46:20 PM
                                                         Ok, understood.
TouchTheSky - 4/23/2018 6:17:02 PM
Tim Dawson - 11/8/2017 11:40:15 AM
popov - 11/22/2017 12:27:21 PM
             www.stratux.me
Telefisch - 11/22/2017 12:47:02 PM
TouchTheSky - 1/9/2018 12:04:47 PM
TouchTheSky - 1/10/2018 10:41:26 AM
rg - 1/10/2018 11:19:16 AM
TouchTheSky - 1/10/2018 11:58:03 AM
rg - 1/10/2018 12:12:11 PM
TouchTheSky - 1/10/2018 12:26:08 PM
techie59 - 2/13/2018 8:36:31 PM
TouchTheSky - 2/13/2018 9:13:27 PM
techie59 - 2/19/2018 1:01:33 PM
popov - 2/20/2018 9:27:42 AM
popov - 2/27/2018 10:18:55 AM
rg - 2/27/2018 10:22:47 AM
TouchTheSky - 2/27/2018 10:45:06 AM
                         Oh wow! I just thought this was a FLARM connection to SD. I hadn't...
rg - 2/27/2018 11:48:35 AM
TouchTheSky - 2/27/2018 10:48:06 AM
popov - 2/27/2018 10:50:46 AM
                         I replaced it with the following: ‌‌...
TouchTheSky - 2/27/2018 11:34:58 AM
                             Thank you :) T‌his was awesome info!
popov - 2/27/2018 11:43:59 AM
                             According to Dan Murray, the benefit of the ground plane is...
TouchTheSky - 2/28/2018 7:27:36 AM
                                 G‌ot to ask just to be sure as English is not my native language: D‌o...
popov - 2/28/2018 7:33:28 AM
                                     No, the other way round. It is a risk to use the ground plane.
TouchTheSky - 2/28/2018 8:08:07 AM
xls125martins - 5/13/2018 2:24:06 PM
PaulSS - 2/28/2018 10:55:11 AM
TouchTheSky - 2/28/2018 11:25:37 AM
KevinWolters - 3/11/2018 2:05:45 PM
TouchTheSky - 3/11/2018 3:22:33 PM
KevinWolters - 3/11/2018 3:52:27 PM
TouchTheSky - 3/11/2018 4:19:57 PM
                         Today i received my parcel from the USA! :D b‌ut unfortunately i...
KevinWolters - 3/23/2018 10:43:51 PM
                             I am not an antenna expert. I did however use the above 868MHz antenna...
TouchTheSky - 3/24/2018 5:07:37 AM
KevinWolters - 3/24/2018 9:49:06 AM
TouchTheSky - 3/25/2018 7:57:03 AM
rg - 3/25/2018 3:40:29 PM
TouchTheSky - 3/25/2018 5:55:05 PM
                         Ok. Thanks. So unless you know how to reverse it I’ll need another...
rg - 3/25/2018 5:59:44 PM
                             Here is a post with some examples how to program two SDRs. ‌...
TouchTheSky - 3/25/2018 8:31:15 PM
KevinWolters - 3/25/2018 11:27:05 AM
TouchTheSky - 3/25/2018 11:50:04 AM
TouchTheSky - 7/18/2018 8:59:58 AM
xray - 7/29/2018 7:03:53 AM
TouchTheSky - 7/29/2018 9:52:15 AM
xray - 7/29/2018 12:33:27 PM
Tim Dawson - 7/18/2018 10:50:57 AM
TouchTheSky - 7/18/2018 10:55:22 AM
Tim Dawson - 7/18/2018 1:35:21 PM
TouchTheSky - 7/18/2018 1:42:10 PM
TouchTheSky - 7/21/2018 6:40:14 PM
neubamat - 8/21/2018 2:25:28 PM
neubamat - 8/21/2018 3:00:01 PM
             Is there an easy fix available?
TouchTheSky - 8/21/2018 3:06:14 PM
neubamat - 8/21/2018 6:13:27 PM
neubamat - 8/27/2018 8:00:39 AM
TouchTheSky - 8/27/2018 2:34:13 PM
neubamat - 8/27/2018 5:57:37 PM
TouchTheSky - 8/28/2018 6:19:36 AM
TouchTheSky - 8/31/2018 8:33:29 AM
neubamat - 8/31/2018 10:03:39 AM
TouchTheSky - 8/31/2018 10:10:52 AM
neubamat - 8/31/2018 1:18:39 PM
TouchTheSky - 8/31/2018 2:33:28 PM
                 exactly :D
neubamat - 8/31/2018 9:33:31 PM
EU001939 - 9/2/2018 9:02:25 AM
             A-EFIS </offtopic>
ArnaudC - 10/3/2018 3:44:28 PM
efrenken - 10/6/2018 10:14:24 AM
Tim Dawson - 9/3/2018 11:13:16 AM
TouchTheSky - 9/24/2018 7:38:39 PM
on5ap - 3/14/2019 12:37:13 AM
Rdkraker - 10/5/2018 3:52:46 PM
TouchTheSky - 10/5/2018 4:54:33 PM
Rdkraker - 10/6/2018 6:11:44 PM
Rdkraker - 10/15/2018 6:08:21 AM
             Try this:...
TouchTheSky - 10/15/2018 7:57:13 AM
on5ap - 3/18/2019 5:19:37 PM
TouchTheSky - 3/18/2019 5:32:02 PM
on5ap - 3/18/2019 7:26:41 PM
pilot-byom - 6/15/2019 12:03:17 PM
b3nn0 - 6/15/2019 12:41:16 PM
pilot-byom - 6/15/2019 2:00:46 PM
joey - 7/9/2019 1:10:37 PM
b3nn0 - 7/9/2019 1:20:56 PM
joey - 7/9/2019 1:28:30 PM
                         I have not tested it personally, but anything RTL-SDR based should...
b3nn0 - 7/9/2019 4:42:58 PM
mxb - 7/9/2019 5:01:20 PM
joey - 7/9/2019 6:10:56 PM
joey - 7/23/2019 3:54:03 PM
pilot-byom - 7/23/2019 5:04:24 PM
Cloudwalker - 4/11/2020 3:17:33 PM
TouchTheSky - 4/11/2020 3:48:58 PM
pilot-byom - 4/11/2020 4:39:47 PM
TouchTheSky - 4/11/2020 4:44:50 PM
                 Thank you! great start!
Cloudwalker - 4/11/2020 7:00:04 PM
screen - 5/17/2020 5:03:51 PM
             Yes
efrenken - 5/18/2020 2:44:51 AM
joey - 7/23/2020 7:59:58 PM
b3nn0 - 7/24/2020 10:21:43 AM
joey - 7/28/2020 7:26:10 PM
Tim Dawson - 7/30/2020 10:59:25 AM
b3nn0 - 7/30/2020 1:55:01 PM
fzahn - 8/3/2020 4:02:37 PM
b3nn0 - 8/3/2020 4:37:16 PM
Exfirepro - 7/30/2020 2:28:12 PM
Maverix - 8/3/2020 10:53:14 AM
pilot-byom - 9/4/2020 9:55:02 AM
b3nn0 - 9/4/2020 10:19:50 AM
                 Thx!
pilot-byom - 9/4/2020 10:25:07 AM
pilot-byom - 9/5/2020 11:05:24 AM
                         all OGN received protocols will still be green, will be displayed on...
b3nn0 - 9/5/2020 5:41:10 PM
                             Just for information, I derived one possible reason for the Flarm...
pilot-byom - 9/6/2020 7:12:49 AM
pilot-byom - 9/23/2020 1:04:23 PM
b3nn0 - 9/23/2020 3:12:12 PM
pilot-byom - 9/24/2020 1:56:24 PM
pilot-byom - 10/6/2020 11:00:45 AM
177 - 2/8/2021 6:30:20 PM
TouchTheSky - 2/8/2021 6:41:16 PM
177 - 2/8/2021 10:07:50 PM
TouchTheSky - 2/9/2021 6:47:16 AM
erchegyia - 8/30/2021 7:17:19 PM
TouchTheSky - 8/31/2021 7:22:13 AM
erchegyia - 8/31/2021 11:00:32 AM
TouchTheSky - 8/31/2021 12:17:32 PM
Fedko - 10/4/2021 11:14:26 PM
TouchTheSky - 10/5/2021 8:56:17 AM
erchegyia - 10/6/2021 7:45:41 AM
b3nn0 - 10/7/2021 7:26:38 AM
erchegyia - 11/1/2021 11:01:01 AM
177 - 11/1/2021 2:12:46 PM
                         and to add some advice - the flat area of the pinkish GPS antenna has...
BJS - 1/15/2022 7:25:41 PM
KeiXiD - 2/10/2022 9:48:24 PM
TouchTheSky - 2/11/2022 6:47:58 AM
KeiXiD - 2/11/2022 12:50:55 PM
TouchTheSky - 2/11/2022 1:46:51 PM
                         That's what he stated in the first question. I have the same settings...
erchegyia - 2/11/2022 1:49:24 PM
                             To see Bearingless Targets in SD, you must use the FLARM Protocol....
Exfirepro - 2/12/2022 12:43:55 AM
                             Im pretty sure there were some planes near
KeiXiD - 2/12/2022 1:57:54 AM
                         I use Flarm with AirConnect but do not use the Setting „Air Avionics“...
KeiXiD - 2/12/2022 1:41:35 AM
                         Mine is set to 192.168.10.1 and Mode-S-Signals doesn't appear on SD...
Fliy - 10/28/2024 4:39:20 PM
                             Maybe yes but latest Stratux version supports BLE and works nicely...
TouchTheSky - 10/28/2024 5:27:21 PM
