Italy - FMC Padova Central - vertical limit not correct
Daniel_KDF
Daniel_KDF
Posts: 57, Visits: 396
I know it is a difficult task to present all the worldwide VFR airspace correctly. However, in case you still strive for this:
In AIP: FMC Padova Central has an upper limit of "lower vertical limit of overlying controlled airspace".
In Skydemon: FMC Padova Central has an upper limit of 5000 ft
(In the screenshot, the overlying controlled airspace starts at FL85, so Skydemon is actually 3500ft off.)
Posts: 8K, Visits: 9.2K
A good proportion of the controlled airspace in your screenshot actually starts at 4500. We had to choose a value for the upper limit of the FMC area so with the advice of an Italian pilot with knowledge of flying in the area we settled on 5000 for the moment.
Daniel_KDF
Daniel_KDF
Thanks, Tim. Good to know that you are aware of this issue.
Obviously it is difficult to handle such "non-standard" airspace definitions, as it would probably require some code changes in your airspace parser and renderer.
