I know it is a difficult task to present all the worldwide VFR airspace correctly. However, in case you still strive for this:
In AIP: FMC Padova Central has an upper limit of "lower vertical limit of overlying controlled airspace".
In Skydemon: FMC Padova Central has an upper limit of 5000 ft
(In the screenshot, the overlying controlled airspace starts at FL85, so Skydemon is actually 3500ft off.)
