SkyDemon Navigation
SkyEcho 2, GDL90 and Skydemon for PC
col-lucy
col-lucy
posted 8/10/2021 12:56:16 PM
Visits: 166
Hi all,
I wonder if anyone has noticed that the PC version of Skydemon reads a different altitude to the Android version when using SkyEcho 2 or other GDL90 data source? I use the PC version of Skydemon when connecting to Flight Simulator 2020, and it also shows the altitude discrepancy. Using SkyEcho at home, the PC version reads 180ft, and the Android version reads 30ft.
I suspect that the Android version is correct and is applying an ellipsoid to geoid correction that the PC version is not. If so, it would be interesting to know what that correction is.
Does anyone have any pearls of wisdom?
Cheers!
Colin Martin
posted 8/11/2021 10:01:28 AM
Posts: 8.3K,
Visits: 10K
Could you contact customer support? They will probably have a record of when the bug was fixed and may be able to supply you with a beta.
col-lucy
Are you using the latest version of SkyDemon Plan? This reminds me of...
8/10/2021 1:07:43 PM
Hi Tim, I'm showing 3.15.4.0 for the PC version and 3.15.4.2225...
col-lucy
8/10/2021 2:09:03 PM
Could you contact customer support? They will probably have a record...
