SkyDemon + PowerFlarm Fusion
Posts: 8.2K, Visits: 9.8K
You said above that the wifi is unable and loses connection, which is something independent of SkyDemon. It sounds like maybe your Flarm device is going wrong when transmitting data through the dedicated Fusion option; perhaps it's resetting itself if the wifi link goes down. That is speculation on my part, though.
If SkyDemon dumps you back to planning mode giving you some invalid input received from the Flarm device, that's another situation entirely. That suggests that it's sending bad data, at which point SkyDemon terminates the connection deliberately.
astf7
a
Posts: 2, Visits: 0
I tested 1.2.2 beta yesterday and it seems to work just fine, no disconnections at all. It will probably be released very soon.
lhe
lhe
Posts: 154, Visits: 445
astf7 - 7/3/2021 10:37:04 AM
You mean 1.2.2 beta of the FLARM Hub firmware?
Edited 7/5/2021 9:12:04 PM by lhe
beersc
b
Posts: 5, Visits: 6
Yes, Flarm contacted me recently saying they found an issue, and provided flarmhub beta version 1.22 to test. It performed flawlessly! So it seems they have solved the issue.
