Lozzi
Visits: 20
Hello everybody, I can't find the Italian FIS boundaries on the main map, while I can see them in the virtual radar (see image below). I searched for a specific layer to enable, but I see no FIS or FIC references. I feel I'm missing something somewhere, but I cannot find it. May you please help? Thank you very much. Regards, Andrea
Visits: 31K
+xHello everybody, I can't find the Italian FIS boundaries on the main map, while I can see them in the virtual radar (see image below). I searched for a specific layer to enable, but I see no FIS or FIC references. I feel I'm missing something somewhere, but I cannot find it. May you please help? Thank you very much. Regards, Andrea
I don’t believe SD shows FIS boundaries on the main chart for any country, not just Italy.
Visits: 388
Skydemon only shows FIR boundaries, as I recall, which is fine with me. What do you believe would be a benefit for FIS boundaries on the map? I'd say the use cases for FIS are all relevant when on the ground only.
Lozzi
Visits: 20
grahamb, thanks for the information. pilot-byom, the main benefit I see is the presence of a visual aid to change the radio frequency on the right time. When you're about to enter a controlled airspace, SD alerts you in the main map to be prepared to contact the right service with the related frequency. When you're about to change FIS, no alert and no visualization of the approaching boundary on the main map. Only a (correct, by the way) reference in the virtual radar, which, of course, is far less efficient (just for example, in the virtual radar the visual position of the boundary depends on your current heading).
Thanks.
Andrea.
Visits: 31K
+xgrahamb, thanks for the information. pilot-byom, the main benefit I see is the presence of a visual aid to change the radio frequency on the right time. When you're about to enter a controlled airspace, SD alerts you in the main map to be prepared to contact the right service with the related frequency. When you're about to change FIS, no alert and no visualization of the approaching boundary on the main map. Only a (correct, by the way) reference in the virtual radar, which, of course, is far less efficient (just for example, in the virtual radar the visual position of the boundary depends on your current heading).
Thanks.
Andrea. Don’t forget that the ‘Radio’ tab will always show time and distance to the next FIS frequency.
Lozzi
Visits: 20
+xDon’t forget that the ‘Radio’ tab will always show time and distance to the next FIS frequency. You're right. I will take the 'Radio' tab more into consideration. Anyway, I still think that a border on the main map, with related alerts - just as other controlled airspaces borders - will help (no need to open and close a tab, which can be annoying especially when the air is not calm).
Thanks a lot.
Andrea.
Visits: 388
+xpilot-byom, the main benefit I see is the presence of a visual aid to change the radio frequency on the right time. No, it doesn't. Which ACC of FIS responsible for your current FIR to call may depend not only on your position, but also on your intentions. You may even find yourself in a certain FIR, but radio services for your flight execution is 'delegated' to an ACC of a FIS not even in your country, if close borders. When under FIS supervision you change when and to as advised from them anyways. If you just listen, you have to pull the FIS options from your thorough flight preparation, which may even include listening to several FIS in parallel, especially in Italy.
Frans
Visits: 28
Exactly, FIS will tell you anyway when you need to change the frequency. The only important thing is to know the frequency for the initial call, and you can find it already easily in the radio tab. I would dislike further border lines in the charts just for FIS. The FIR-boundaries are enough.
Posts: 8.3K,
Visits: 10K
If we were ever to show FIS boundaries on the map, it would certainly be optional, and probably off by default. People are accustomed to seeing them because they're absolutely necessary on printed charts, but on a dynamic chart that supports interrogation like SkyDemon, there's no need for them to be shown all the time.
Visits: 31K
Something I’d forgotten about but have been reminded of on another forum, is that when you have the Radio tab open and touch one of the frequencies displayed, it will temporarily highlight the relevant service area on the main chart.
