Xmas present wish list
Clive
Clive
Too Much Forum (587 reputation)Too Much Forum (587 reputation)Too Much Forum (587 reputation)Too Much Forum (587 reputation)Too Much Forum (587 reputation)Too Much Forum (587 reputation)Too Much Forum (587 reputation)Too Much Forum (587 reputation)Too Much Forum (587 reputation)
Posts: 34, Visits: 6
Things I’d like to see which have never been added after all these years:
When pinging airfield tab the main freq and airfield height are shown against the airfield name, this would save further screen changes to fond them out.
When pinging the Radio tab the destination main freq is top of the list.
When pinging ‘direct to’ the original destination is top of the list. This enables resetting the route easily when you’ve been bumbling and you decide it’s time to head to where you want to go.
Merging logs works even when ‘the flight appears to start from a takeoff’ and so logs interrupted by circuits and low passes can be merged. Or logs don’t automatically stop and start when you go near or onto the ground.
I use SlyD extensively all over and the lack of these features has always bugged me.
Version 3.14.6.278
Thanks for reading, have a good festive.....;-))
Ok, I'll give it a try to comment. I second to move this to suggestions!
Adding ELEVB and RADIO to the Favorites at the Airfields tab directly gets my +1.
I can see how this could be useful on a tablet, but not on a small smartphone screen. I like the current logics of NOW, by DIST, DEST much better.
Never had a check there. Am I correct top of the list is always the home base? Iy any change, I'd prefer the favorites on top and not something from current root. You can always tap the airfield and do a direct to there, but direct-to-flying is kind of sloppy anyways. Your request seems to address a special way you do your flights. I would rather see a 'resume' or 'back to filed route' function similar to intercept procedures in IFR and that will bring you back to your flight plan of waypoints, not directs.
Never had that issue. Yes, if logs are too far away in time from each other you cannot merge in Skydemon, but you simply can do that outside by cut&paste. But, what for?
Version 3.14.6.278
Enjoy a healthy christmas and see you in suggestions box thereafter!
Clive - 12/22/2020 6:28:46 AM
grahamb - 12/22/2020 7:09:17 AM
Tim Dawson - 12/22/2020 10:21:33 AM
pilot-byom - 12/22/2020 11:13:38 AM
grahamb - 12/22/2020 1:44:03 PM
Tim Dawson - 12/22/2020 2:23:16 PM
Clive - 12/22/2020 8:40:06 PM
BAW705 - 1/7/2021 8:44:42 AM
             Whereabouts are you Amir? Regards, Clive
Clive - 1/7/2021 9:11:37 AM
                 Hi Clive, Middle East - Iran
BAW705 - 1/7/2021 11:32:57 AM
Clive - 1/7/2021 11:42:24 AM
                         Good to hear from you too. Well, it is not certainly like UK or US,...
BAW705 - 1/7/2021 12:09:54 PM
                             I was thinking of the National charts, didn't know the extent of...
Clive - 1/7/2021 5:34:28 PM
                                 I see the AIP is pretty much cover it all as a free source, Jeppesen...
BAW705 - 1/7/2021 5:44:09 PM
