Custom objects to the map?
bjornbostrom
b
Posts: 5, Visits: 52
Hi!
Is it possible to add custom objects to the base vector map? As churches are quite common to use as navigation aids in VFR, I would like to add them to the map.
* For now I have created a Waypoint folder, where all the churches go, but lack of a church symbol makes it to look rather terrible on the map.
* I've tried to add a custom data layer (obstructions) with "Place of Worship" type. But they all shows with an "antenna" symbol. Also the name is not written on the map, and they are not searchable
Castles seems to (sometimes) be included in the basemap with a brown icon - is it possible to add such custom objects? They look nice... However they seems not to be searchable either?
(errormessages when including images in topic, see screenshot here: http://www.boztrom.com/skydemon/slott.jpg )
// björn
Posts: 8.2K, Visits: 9.6K
No, you cannot create such custom objects on the map in SkyDemon.
You could use an emoji for a user waypoint name, but I don't know if that would help.
