Skydemon starting new log
SkyDemon Team (710K reputation)SkyDemon Team (710K reputation)SkyDemon Team (710K reputation)SkyDemon Team (710K reputation)SkyDemon Team (710K reputation)SkyDemon Team (710K reputation)SkyDemon Team (710K reputation)SkyDemon Team (710K reputation)SkyDemon Team (710K reputation)
It sounds like you're letting SkyDemon log your flights automatically, in which case if you land, and stop, we will indeed finish that log.
If you start the log yourself (by logging engine on, or off blocks) then you can also stop the log yourself.
dcoquelet
d
Too Much Forum (137 reputation)Too Much Forum (137 reputation)Too Much Forum (137 reputation)Too Much Forum (137 reputation)Too Much Forum (137 reputation)Too Much Forum (137 reputation)Too Much Forum (137 reputation)Too Much Forum (137 reputation)Too Much Forum (137 reputation)
Posts: 13, Visits: 175
danGigantic - 11/29/2020 7:37:49 PM
When ever I fly to a new airfield land, backtrack and takeoff again Skydemon will restart and log as a new flight and delete the breadcrumbs (as they aren't associated with the current flight). Is there and option to stop this and to log the complete flight only when i exit navigation mode?
You can merge the two logs afterward
danGigantic
d
Posts: 6, Visits: 3
