PilotAware aircraft icon size
Merlin29
M
Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)
Posts: 4, Visits: 0
Tim Dawson - 6/12/2020 8:47:42 AM
It sounds like you'd benefit more from the size of the text being changed, rather than the size of the icon, is that correct?
Hi Tim, yes the text. Not the icon. And only the next for the relative separation e.g +0.2. Not to fussed about the aircraft reg text. Many thanks.
ChrisRowland
C
Too Much Forum (69 reputation)Too Much Forum (69 reputation)Too Much Forum (69 reputation)Too Much Forum (69 reputation)Too Much Forum (69 reputation)Too Much Forum (69 reputation)Too Much Forum (69 reputation)Too Much Forum (69 reputation)Too Much Forum (69 reputation)
Posts: 7, Visits: 12
If there's a threat then what I want to do is get my head outside looking for it, not peering at a screen.
So all I want is a rough idea of where to look.
So far I've had one real SkyEcho/SkyDemon alert and the beastly helicopter appeared in the horizon clutter slightly below me, just where SD said it was.
I'm not sure how SD could have given me more useful information.
willjohnh
willjohnh
Too Much Forum (345 reputation)Too Much Forum (345 reputation)Too Much Forum (345 reputation)Too Much Forum (345 reputation)Too Much Forum (345 reputation)Too Much Forum (345 reputation)Too Much Forum (345 reputation)Too Much Forum (345 reputation)Too Much Forum (345 reputation)
Posts: 3, Visits: 9
Merlin29 - 6/12/2020 2:12:23 PM
I'd also request this. I think it is a question of text size and perhaps contrast against the background. I find the vertical separation is the most important info (if available). Less bothered about reg info but this is still useful especially if flying as part of a group.
TimT
TimT
Posts: 89, Visits: 92
Apart from the text *size* it is may also be a matter of syntax used to denote vertical separation. I prefer to see relative altitude stated in "hundreds of feet", like normal TCAS systems would do. And like it is equally the conventional way to denote flight levels. So for example:
"80" for 8,000 FT
"3" for 300 FT
Doing it is "thousands of feet" just creates leading zeros and commata without meaning. Why say (for 300Ft) "+0.3", if you can just say "+3", etc. That would help decluttering the display.
joey
joey
Too Much Forum (153 reputation)Too Much Forum (153 reputation)Too Much Forum (153 reputation)Too Much Forum (153 reputation)Too Much Forum (153 reputation)Too Much Forum (153 reputation)Too Much Forum (153 reputation)Too Much Forum (153 reputation)Too Much Forum (153 reputation)
Posts: 7, Visits: 10
I would also like the option to display other aircraft more prominently (larger size, different color, stronger contrast, whatever).
Maverix
M
Too Much Forum (621 reputation)Too Much Forum (621 reputation)Too Much Forum (621 reputation)Too Much Forum (621 reputation)Too Much Forum (621 reputation)Too Much Forum (621 reputation)Too Much Forum (621 reputation)Too Much Forum (621 reputation)Too Much Forum (621 reputation)
Posts: 53, Visits: 14
joey - 7/23/2020 8:09:25 PM
Tim,
please make target icon and text size customizable!
Also the text size from bearingless targets. It's almost impossible to see the height of the bearingless target and the bearingless target is not shown on the radar screen.
Thanks.
efrenken
efrenken
Posts: 265, Visits: 3.5K
I support the request to make the target icon and the associated text (at least altitude) more prominent.
As long as this info stays as small as it is, my head-down-time in the cockpit will be unnecessary long.
Eric
