Suggestion to improve the Search/Direct-To dialog ....
drnicolas
drnicolas
Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)
Posts: 99, Visits: 114
Tapping Direct-To in Menu during flight opens the according dialog-box with a sorted list of waypoints nearby.
So far, so good.
Normally, i do not want to go to one of the listed waypoints, but need to search for a waypoint.
To do this, i have to tap "search" and then enter the waypoint or parts of its name.
I would like to see the search-textbox right in the direct-to dialogue with the cursor already positioned in the text box.
IMHO, this can optimize the typical "workflow" for going direct-to somewhere.
It should be easy to change the behaviour of SD. It does not really add a new function
Renzo
R
Posts: 55, Visits: 120
Hi drnicolas and Tim,
in my opinion „dr‘s“ suggestion would be a good improvement to that „direct to“ dialogue. It saves one step in entering the new destination. Drnicolas, did you by the way know that you can open that „direct to-dialogue“ straight with a long tap on the blue SD-dot while in flying mode?
Best regards,
Renzo
drnicolas
drnicolas
Renzo - 1/15/2020 10:53:44 AM
Hi drnicolas and Tim,in my opinion „dr‘s“ suggestion would be a good improvement to that „direct to“ dialogue. It saves one step in entering the new destination. Drnicolas, did you by the way know that you can open that „direct to-dialogue“ straight with a long tap on the blue SD-dot while in flying mode? Best regards,Renzo
No -completely new for me.
Nevertheless, it does not change my suggestion from the original posting.
I think, this would be easy to achieve.
