Bearingless targets on traffic screen
FlightDek
FlightDek
posted 5/15/2019 8:26:31 PM
Visits: 15
I use a phone for traffic awareness connected to a PilotAware. I set the phone to the traffic screen and it make it easy to spot stuff that comes in range. However it doesn't show bearingless target at all. Any chance of just having the detected aircraft ID colour coded somewhere on the screen with relative altitude? It would make it a lot easier to decide whether an altitude change would help separation. I know I can get the info from the ring drawn around my aircraft on my tablet display but it can be difficult making out the relative altitude against the map background and my aircraft trajectory line
Dek
Bealeyman
Bealeyman
posted 1/5/2020 8:30:54 PM
Visits: 103
See image showing clutter about relative height. Taken on a flight two days ago. Software upto date on mini IPAD. If it had been bearingless 'traffic' it would have taken a lot of head-in-cockpit time to figure out. Is the 'fix' mentioned by TD going to fix this ?
FlightDek
Your comment about difficulty in reading the relative altitude on the...
Bealeyman
9/7/2019 10:22:43 PM
Could you perhaps post a screenshot here illustrating a situation you...
9/10/2019 2:17:02 PM
I will try ASAP.
Bealeyman
9/11/2019 3:17:15 PM
Here is one screenshot that exemplifies the problem: The...
TimT
12/14/2019 12:05:02 PM
We've reviewed this display ready for the next version. It's now...
12/16/2019 10:36:12 AM
See image showing clutter about relative height. Taken on a flight two...
Bealeyman
1/5/2020 8:30:54 PM
It's now offset from forward by 30 degrees so should never interfere...
1/6/2020 11:37:09 AM
Thanks for the update. I look forward to getting it. All the best for...
Bealeyman
1/6/2020 5:29:58 PM
That was a good improvement. However, in portrait mode, and subject of...
TimT
10/18/2020 2:09:02 PM
